P0174 Code different variables though
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bamahoyt, Jul 11, 2022.
  1. Jul 11, 2022 at 1:48 PM
    Bamahoyt
    Bamahoyt [OP] Well-Known Member
    Ted
    Knoxville, TN
    2014 TRD Sport DC LB 4x4
    -2014 sport 4.0L with now. 220k miles.
    I have been noticing my truck being slightly sluggish and then a couple days later I threw a CEL and trac off light. Checked codes today and it was a p0174 lean bank 2. I have been trying to sort through things but after clearing code it’s taking about 250 miles for it to throw the code again. If it’s a A/F sensor, would it not throw the code sooner? Other thoughts are fuel pump, pin hole in vacuum hose somewhere and I still need to clean the MAF sensor. Jus thought it curious that it took so long for it to throw the code again
  2. Jul 13, 2022 at 8:04 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Well my CEL and Trac Off Lights turned off this evening. Not sure how that happened. Does that help give any clarity to potential issues?
  3. Jul 13, 2022 at 8:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If I were to guess, you may have a power/ground issue.
    I’d start at the ABS module with the codes you have currently.
  4. Jul 14, 2022 at 5:15 AM
    Bamahoyt
    Ted
    Knoxville, TN
    I’ll take a look. I confused how the abs could cause the p0174 lean code
  5. Jul 14, 2022 at 6:53 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I suspect he was trying to reply to a different thread, the Trac Off light almost always comes on with an engine light.
    I would want to look at long and short term fuel trims on both banks at idle and while driving, if there is a big difference between banks I would suspect an Air/Fuel ratio sensor that is lying, if they are close to the same then vacuum leaks, MAF, and fuel pressure would be things to check.
    tirediron likes this.
  6. Jul 14, 2022 at 7:32 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    ^^ This.
  7. May 11, 2023 at 3:16 AM
    Bamahoyt
    Ted
    Knoxville, TN
    Started driving my truck again for work and still dealing with this issue. How would I go about looking at these Fuel trims? I have now replaced the battery, cleaned MAF, new gas cap for good measure. Comes one roughly 240 miles into driving. It did go 5-6 175mile one way trips without throwing the trac off and check engine lights and then had a longer 300mile trip and threw the lights right around the 250mi mark.
  8. May 11, 2023 at 6:19 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Scan tool
    TnShooter likes this.
  9. May 12, 2023 at 10:46 AM
    Bamahoyt
    Ted
    Knoxville, TN
    Well finally got to read the code and what I assumed was another p0174 is actually a p2197 so the saga continues
