p0174/p0170 Too lean, please healp
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtullis, Jul 13, 2020.
  1. Jul 13, 2020 at 12:30 PM
    jtullis
    jtullis [OP] New Member
    2006 V6 Tacoma Prerunner 2WD
    I have had an issue of poor throttle response and rough idle for a while now, so I decided to get off me a#@ and fix it. Went to the Auto store and found I had a P0174 and p0171 code in the truck (06 V6 late year Prerunner). A quick search led me to Throttle Position Sensor, cleaned throttle body = no change. Since it was gummed up I "figured" that it was the culprit, $485.95 later the truck is better but still has the same codes and same issue, if not as bad. More google lead to Mass Air Flow sensor cleaning, $95.50 and a new sensor... again better but still have similar issue. and I am assuming the same codes. Last time I had the reader it was saying Bank 1 too lean while I was reading the codes and clearing after MAF swap. Do I just go ahead and spend the $400 on O2 sensors, or is there a better way to dial into the actual problem? Or am I just wasting my money? let the beating commence......
  2. Jul 13, 2020 at 1:21 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Start with vacuum hoses.
    Have you checked the PCV Valve and hose.
    Do you have an exhaust leak?
    Muddinfun likes this.
  3. Jul 13, 2020 at 2:31 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    You're just throwing money at it. Bring it somewhere that knows these trucks.
    Muddinfun, TnShooter and 12TRDTacoma like this.
  4. Jul 13, 2020 at 2:37 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Unless you have an actual scanner and are going to use reliable parts, stop messing with it and take it somewhere where they know what they are doing, and know what things to look for.
    TnShooter likes this.
  5. Jul 13, 2020 at 5:32 PM
    jfoster92
    jfoster92 Well-Known Member
    Justin
    Farmerville, la
    08 Tacoma prerunner v6/manual
    How many miles? Your fuel pump could be getting clogged. I just ordered the URD kit because there’s no changeable filter on the Tacomas.
  6. Jul 13, 2020 at 7:55 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Did not see a P0170 code in the FSM
    Google came up with this:
    The P0170 code means that the powertrain control module is detecting a fuel trim that is outside the range of specification set by the vehicle's manufacturer. This can mean a negative fuel trim or a positive fuel trim has been detected.
    What follows is from the FSM
  7. Jul 13, 2020 at 8:01 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's a P0171 code not a P0170. Lean on bank 1 and 2 basically. It could be MAF, injectors, or a fuel pump or a combination of things. Without proper data to help diagnose, we can't do nothing for him.
    I'm telling you, if he can't even post up the right codes, he should NOT be fucking with his truck.
  8. Jul 14, 2020 at 11:45 AM
    jtullis
    As I said let the beating commence. I greatly appreciate the correction and direction.
  9. Jul 14, 2020 at 11:55 AM
    Muddinfun
    Muddinfun Well-Known Member
    Reminds me of a saying my father had. There was 1 thing wrong with it. The owner fixed 6 things and now there's 7 things wrong with it.
  10. Sep 7, 2020 at 3:32 PM
    Bryansantos
    Bryansantos New Member
    Im following these we have the exact same problem loosing power then after a minute of engine off it came back to normal but after less than 50 miles its happening again by any chance did you get it fixed by now? If so what part? Already changed my MAF sensor and sparkplugs already used 3 different types of clogged cleaner fuel cleaner and cataclean cleaners Thank you and i will appreciate your reply if you get that fixed thank you
