P0300
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dawn Patrol, May 30, 2023.
  1. May 30, 2023 at 5:16 AM
    Dawn Patrol
    Dawn Patrol [OP] Active Member
    2011 V6 Double cab SR5 6 foot bed
    Hey all,
    Little bit of a mystery on my 2011 v6
    I went to pass a guy doing about 40 in a 50 yesterday and upon acceleration the truck stuttered a little and the check engine light started blinking. I got around the guy, but I pulled over and hooked up my code scanner pending p0300 misfire in two or more cylinders. I shut the truck off and started it again, no more check engine light. Made it the 40 minutes home without incident.
    Any ideas? I'm thinking spark plugs?
  2. May 30, 2023 at 5:57 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
  3. May 30, 2023 at 6:29 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  4. May 30, 2023 at 12:47 PM
    Dawn Patrol
    Excellent, thanks.
    I'm certain it has been a lot more than 30K since the plugs were replaced. I had a coil fail this winter as well, so I may just go through the ignition system completely.
  5. Jun 1, 2023 at 2:50 PM
    Dawn Patrol
    Update. All of the spark plugs looks like this:
    Could that have caused a misfire?
    About a .078 gap on most of them
  6. Jun 1, 2023 at 2:53 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    100%
  7. Jun 1, 2023 at 4:10 PM
    Dawn Patrol
    Thanks. Valve cover seals are next. Found a little bit of oil on one of the plugs too.
  8. Jun 3, 2023 at 9:03 AM
    Dawn Patrol
    So I was looking at the plugs I pulled out again and one of them was pretty oily on the electrode. IMG_20230603_120000744.jpg
    Could oil have gotten this far down the plug from a bad tube gasket? Or would this be an indication that something is going on in the cylinder itself?
    Truck is running much smoother with new plugs, but I guess that's kind of a given
  9. Jun 3, 2023 at 9:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Plug could have been closest to the intake that vents crank case gases into the combustion chamber.
  10. Jun 3, 2023 at 9:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Toyota V6's will always have one plug that has more oil on it than the others. Its just the way the crank case vents into the intake.
    asuchemist likes this.
  11. Jun 3, 2023 at 9:19 AM
    Dawn Patrol
    I believe it was the 6th cylinder in the firing order. So the one closest to the driver if that makes sense.
    Good to know, thanks!
    chris4x4[QUOTED] likes this.
  12. Jun 3, 2023 at 9:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats the one I figured it would be on your truck.
  13. Jun 3, 2023 at 9:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Make sure all your electrical connections are good too.
