P0301 code and missing
Discussion in '1st Gen. Tacomas (1995-2004)' started by Petrol, Dec 22, 2013.
  1. Dec 22, 2013 at 7:05 AM
    Petrol
    Petrol [OP] Well-Known Member
    Central Va.
    Tacoma
    I just got a bad miss and a P0301 code. The plugs should be good >3k miles on them. I'm guessing its a bad coil pack and I'm getting ready to swap that coils to see if the problem follows the coil location. How often do the coil packs fail?
  2. Dec 22, 2013 at 7:24 AM
    Sin
    Sin Well-Known Member
    Superior, Wisconsin
    1996 Tacoma SR5 4x4 excab 3.4
    I would try a couple of easy things first. Clean MAF sensor and dump some fuel injector cleaner in tank. Changing coil packs is alright but if that doesn't work I guess next thing would be to swap out fuel injectors.
    How many miles on your Taco?
    Even if you just put plugs in one of them could be bad. Happened to me, ended up throwing a brand new plug away.
    Well just giving you a few things to look at. Good luck!
  3. Dec 22, 2013 at 7:45 AM
    Petrol
    Central Va.
    Tacoma
    100k+ , I swapped the #1 coil pack for the #4 (easy to get to) and it's now throwing P0304 code ...So I think I've found my problem.
  4. Dec 22, 2013 at 8:19 AM
    Sin
    Superior, Wisconsin
    Great! Their around 60 bucks at Rock Auto, no idea what the Toyota dealer will want.
  5. Dec 22, 2013 at 9:06 AM
    Petrol
    Central Va.
    Tacoma
    $80.00 at Advance auto but it's Sunday and that's the price you pay to have all 4 cylinders firing. It did fix the problem. Thanks
    Any idea how common that failure is?
  6. Dec 23, 2013 at 10:08 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    I've only had one go, and I'm pushing 225k miles.
  7. Dec 23, 2013 at 11:30 AM
    Petrol
    Central Va.
    Tacoma
    10-4, I'm trying to decide if I want to obtain a spare or just take my chances with the 3 older coils.
  8. Dec 24, 2013 at 5:24 AM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    Just take your chances. If anything buy an oem and keep aftermarket as spare.
