P0301 Misfire Code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kmart6, Jun 11, 2020.
  1. Jul 8, 2020 at 8:18 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    You only take out the efi fuses for the compression check so you don’t get showered in gas. I like to pull the fuses first. Then - with spark plugs still in - crank until it dies And then do the check.
    that said, you should make your own thread in the first gen section (this is 2nd). Your random misfires indicate another problem then the OP’s
  2. Jul 8, 2020 at 9:38 AM
    Ali daud
    Ali daud Member
    2002 tacoma
    Alright thank you
  3. Jul 27, 2020 at 7:04 AM
    Kmart6
    Kmart6 [OP] An Average Joe
    MD
    08 2.7 5spd
    Update: Replaced cylinder 1 fuel injector which has solved the problem.
    durtkillon likes this.
  4. Aug 2, 2020 at 8:28 AM
    EME
    EME Well-Known Member
    Nick
    05 Tacoma sport
    stumbled on this thread, mine has a misfire on cyl 1 as well, I swapped coil and plug with another cyl, and sure enough code came back cyl 1 misfire, just got an injector will replace today, mine was only doing it on first start of the day or if it had sat for a few hours, and not every start either, I'm just guessing its leaking down and flooding the cyl, causing the misfire
    will update later as well
    Jimmyh likes this.
