P0301 Misfire cylinder 1. 2015 2.7L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by twigg1012, Aug 20, 2024.
  1. Aug 20, 2024 at 4:55 PM
    twigg1012
    twigg1012 [OP] Member
    Chasing a problem with a misfire on cylinder one only on my 2.7l tacoma. If I reset the code it runs fine, but it seems once the ECU re-learns then the problem comes back. Results in a rough idle mostly.
    What I've done so far:
    New plug
    Swapped coils
    Replaced coil( for my sanity)
    Cleaned the MAF
    Scoped the cylinder, was a little wet but didn't see anything odiously wrong.
    Next up is the injector tomorrow, but it smelled as though it was running rich on startup, not lean.
    Someone suggested the ECU, but I am hesitant to think that could be the issue without another code.
    What else should I be looking at besides a compression test? It's not losing coolant so I believe the head gasket is fine.
  2. Aug 20, 2024 at 8:40 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Very doubtful it's the PCM, if it only misfires at idle I'd more suspect a compression issue.
    I think start with a compression test and see if you have a low cylinder.
    TJTM likes this.
  3. Aug 28, 2024 at 3:40 PM
    twigg1012
    Compression is 120-130~ across the board. Low but doesn't vary too much.
