P0301, Tried everything, Suggestions?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SlowTaco88, Jul 14, 2025.
  1. Jul 14, 2025 at 8:27 PM
    SlowTaco88
    SlowTaco88 [OP] Member
    2015 2TR RWD
    Hello, new/old member here, had a 2018 a few years back, sold it for a hybrid lease, ended up back here in a used 2nd gen.
    Anyway, info on the vehicle
    2015 2.7L RWD SR5 with 168k on it
    Some info about myself, been working on cars with my father since I was old enough to hold a tool, he was a master tech at Toyota for 35+ years, we are both stumped by this issue.
    About 2 weeks ago I got a code P0301, figured start with the basics check the plugs, looked original, got new NGK iridiums and installed. Pending code came back after a few cycles.
    Swapped coils, again, came back after a few cycles, same code for cylinder 1 misfire.
    No signs of coolant in the oil, no coolant usage or oil usage, still averaging 24.6mpg, runs fine after a rough start that lasts 2-3 seconds. No puff of white smoke, no strange smell, no sign of head gasket leak or failure.
    Swapped injectors 1 and 4, also checked fuel pressure at this point. 41-43psi while running, drops to 30-32psi when shut off and stays there for roughly 10 minutes, drops to 22psi after 1 hour. (Is this right?)
    Did block test, fluid remained blue
    Did compression test:
    Cyl 1: 170
    Cyl 2: 165
    Cyl 3: 165
    Cyl 4: 175
    Did leak down test, no hissing from anywhere etc, all cylinders tested around 5-10% this was done with a cheaper setup from Amazon so I’m not sure how accurate that thing was, may have to revisit this test.
    Checked plugs again, plug 1 had carbon build up and a dark spot on the electrode insulator, crush washer not crushed, weird because we had tightened it down, also threads dirty further up than every other plug. Plug was dry, just sooty buildup. Swapped plugs 1 and 4, made sure to tighten again. This is the only questionable thing we had found, the threads on both the compression and leak down tester were shorter and they both sealed but the plug itself looks like it got 3/4 of the way in and then tightened up, maybe threads are messed up and the plug isn’t seating all the way? Not sure on this one, going to have to check again.
    There is no pattern to this pending code, it happens day or night, cold or warm start, parked uphill or downhill. It can happen twice in a day or once in a few days. There’s no consistency to it at all. Always cylinder 1 misfire, doesn’t always go past pending because it’s so random. No other codes, the only hint I get is the rough 2-3 second start and then plug in the scanner and see it. No power loss, no other stumbling or idling funny.
    My father and I are stumped, I’m going to pull plug 1 tomorrow and check it again, I will also be checking the cylinder and valves out with a borescope but with the problem being so inconsistent I don’t know if or when I’ll see anything.
    Any suggestions are greatly appreciated! Maybe there’s a test we missed or something we haven’t looked at.
  2. Jul 14, 2025 at 8:35 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’m going to guess spark plug tube gaskets are toast and letting oil wick up the outside of plug and into the coil.
  3. Jul 14, 2025 at 8:39 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Being it only happens at startup I think I'd want to pressurize the cooling system and look for coolant dripping in the cylinder with a borescope. It only takes a few drops to cause a misfire.
    https://www.youtube.com/watch?v=Rurhi-IGaiU
  4. Jul 14, 2025 at 8:39 PM
    SlowTaco88
    2015 2TR RWD
    no oil on or in any of the coils or tubes that we could see.
    Steves104x4[QUOTED] likes this.
  5. Jul 14, 2025 at 8:46 PM
    SlowTaco88
    2015 2TR RWD
    This is why I want to run the scope into it tomorrow, it’s just odd because even sitting a few hours, few days etc sometimes it happens sometimes it doesn’t. I’d think if the cooling system got up to temp and I shut it off, the next morning it would do it every time. I’ll give it a go, never know, honestly if it is a head gasket, yeah that sucks but it’s such a small leak at least it’s caught early before anything really detrimental to the engine happens. I don’t look forward to a headgasket change and rebuild but at least I can do it myself for far less.
  6. Jul 14, 2025 at 8:49 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I mean hopefully it's not but that is the most common cause of a misfire on startup that goes away after a few seconds, certainly something I would want to check/rule out before doing anything else.
  7. Jul 14, 2025 at 8:53 PM
    SlowTaco88
    2015 2TR RWD
    That’s what I keep reading, I’m hoping it’s something we overlooked on it, but it’s seriously approaching the head gasket issue at this point. I’ll give it a look tomorrow, crossing my fingers I don’t have to get that far into it.
  8. Jul 15, 2025 at 8:23 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    perhaps this might help - more potential candidates
  9. Jul 15, 2025 at 9:25 AM
    SlowTaco88
    2015 2TR RWD
    I will go down that list and check everything if the scope goes well, thank you
  10. Jul 16, 2025 at 6:49 PM
    SlowTaco88
    2015 2TR RWD
    Well, I finally figured it out, and looks like I’m ordering a head gasket kit etc, camera revealed a very very small leak but it’s enough to be problematic, this should be fun.
    Dm93 likes this.
  11. Jul 16, 2025 at 7:59 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Dang, well at least mystery solved.
    I'm not sure why but it seems headgasket issues are becoming more and more common on both the 2.7 and the 4.0 as these are getting older now, not sure if it's a coolant maintenance issue or if it's just heat cycling is eventually causing the gasket to fail.
    They often don't leak bad enough to cause any overheating or to test positive on a combustion gas test but leak just enough into the cylinder to cause a cold start misfire.
  12. Jul 16, 2025 at 8:20 PM
    ChessguyTaco
    ChessguyTaco Well-Known Member
    L
    I was going to say bad gas or water or some sort of condensation crap getting into the fuel system hence causing a bad air/fuel mixture. Yeah, i know...seems like the story only fits in my head. Glad you got it all figured out.
  13. Jul 17, 2025 at 6:12 AM
    tak1313
    2013 Base 2WD
    The head gasket problem is also a VERY common problem with the Gen3 Prius (2010-2015) and would also manifest (initially) as misfire at startup (along with shaking and rough running until the coolant in the cylinder is burned off).
    PERHAPS it was a quality problem the head gasket source that Toyota used at the time?
  14. Jul 17, 2025 at 7:32 AM
    SlowTaco88
    2015 2TR RWD
    very possible, makes me hesitant on ordering the gasket kit from Toyota directly, but it does look like it has been updated with new part numbers over time.
  15. Aug 25, 2025 at 4:13 PM
    SlowTaco88
    2015 2TR RWD
    Took a week and a day only working on it 2-3 hours each day, but it is all back together. I did end up going with OEM parts, just got the entire gasket and seal kit. No leaks, double checked everything and it’s running great! Thank you to everyone for the help/suggestions!
    Stubert90 likes this.
