P0301 troubleshooting and diagnosis
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco 422, Feb 24, 2023.
  1. Feb 24, 2023 at 12:03 PM
    Taco 422
    Taco 422 [OP] Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    260xxx on the clock and I'm experiencing a minor to moderate shudder upon accelerating up an incline on pavement. It seems to shift into second or third and take off from there without incident.
    Driveline U joints and carrier bearing replaced about 2.5 years and 60-70 thousand miles ago.
  2. Feb 24, 2023 at 12:09 PM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Have you checked them again?
    SR-71A likes this.
  3. Feb 24, 2023 at 1:57 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    When was the last time transmission fluid was changed
    ToyoTaco25 likes this.
  4. Feb 24, 2023 at 9:52 PM
    Taco 422
    USA
    About three years ago. I checked the level about two months ago and it was a little high.
    not yet, it's been stormy and the shudders just started within the last week - they're on the list for Monday when it's supposed to be dry.
  5. Mar 2, 2023 at 1:10 AM
    Taco 422
    USA
    Just got a bad shudder and flashing CEL at 50mph, and misfire on idle.
    waited 5 hours (1a-5a) for a tow. AAA is terrible.
    I'm thinking bad coil, heading to the shop to grab my computer, fingers crossed.
  6. Mar 2, 2023 at 3:37 PM
    Taco 422
    USA
    I've only got a P0301, i'm working on pulling the spark plug.
    Any input?
  7. Mar 2, 2023 at 3:38 PM
    Taco 422
    USA
    I have now, everything seems solid in the drivetrain
  8. Mar 2, 2023 at 6:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Swap #1 plug with #3 plug.
    Swap #1 coil with #2 coil.
    See if the miss stays, or follows the plug or coil.
    A P0301 won’t be cause by the transmission or u-joints.
  9. Mar 2, 2023 at 7:57 PM
    Taco 422
    USA
    Yeah, there was a shudder initially I couldn't place, the code popped up last night with a pronounced misfire. I'll follow your procedure when the suns up. Thank you.
    TnShooter[QUOTED] likes this.
  10. Mar 3, 2023 at 1:01 PM
    Taco 422
    USA
    I've found both valve cover gaskets to be leaking.
    the #1 spark plug is "normal" and reeks of gasoline.
    parts ordered.
    HondaGM likes this.
  11. Mar 3, 2023 at 1:06 PM
    TnShooter
    Deogee
    STOCK
    Were the plug wells full of oil?
    HondaGM likes this.
  12. Mar 3, 2023 at 4:49 PM
    Taco 422
    USA
    There's a noticeable amount in each but it's not dripping.
