P0302 #2 cylinder misfire/help
Discussion in '1st Gen. Tacomas (1995-2004)' started by eric70412, Oct 7, 2014.
  1. Nov 6, 2021 at 9:12 AM
    Jimmyrace
    Jimmyrace Well-Known Member
    JR
    Louisville, KY
    Betty '03 Taco MTM Xtra-cab DLX 5VZFE
    OME struts / springs / leaf pkg :: SPC upper A ::
    imho - save some time before any further troubleshooting & perform that compression test
    JudoJohn likes this.
  2. Nov 6, 2021 at 9:22 AM
    16 Bore
    16 Bore Well-Known Member
    ‘02 Ext Cab 2.7 4X4 5sp
    I washed it once or twice
    I did have a valve cover bolt that was finger tight and torqued it back.
    Hmmm...
    Fast forward now I notice I only get misfires on the way home from work, after it’s sat in the sun all day. And like clockwork. The last stint didn’t show up on my code reader, just the 440 and 441 which has been there for about 10 years.
    Valve cover gasket replacement time it sounds like??
    Jimmyrace likes this.
  3. Nov 6, 2021 at 9:24 AM
    16 Bore
    Oh, and plugs are about 6 months old. Wires original. All but 1 coilpack has been replaced. Those either work or they don’t. The misfire isn’t at that cylinder. Unless #1 is closest to the firewall and not the radiator.
  4. Nov 6, 2021 at 10:49 AM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    X2
    Jimmyrace[QUOTED] likes this.
  5. Nov 6, 2021 at 10:52 AM
    JudoJohn
    St. Louis
    90 psi is a lot lower and that may be why you have the misfire. could be the head gasket going out, or a burnt valve.
  6. Nov 6, 2021 at 1:34 PM
    16 Bore
    Will do. Is it rocket science or just a matter of buying a few tools/gauges? I’ve never done it before, but I’m not inept.
    Reckon I’ll do some YouTubing.
  7. Nov 6, 2021 at 1:50 PM
    JudoJohn
    St. Louis
    it's easy. get a compression test gauge ((you may be able to borrow at parts store). remove spark plugs. adapter screws into spark plug threads (make sure you do this by hand) tighten it, connect the gauge, and tne crank the engine over a couple times.
  8. Nov 6, 2021 at 2:18 PM
    16 Bore
    Sounds pretty simple, I’ll report back to the pros here and see what kinda mess I’ve gotten myself into!!
  9. Nov 7, 2021 at 10:14 AM
    ArizonaBrian
    ArizonaBrian Well-Known Member
    I don't know how it is on the other engines but the 6-cylinder 5vz uses a waste spark system. If your engine is the same (you would have half the number of coils as spark plugs) a bad coil would produce misfires on two cylinders not just one.
  10. Nov 8, 2021 at 9:19 AM
    Jimmyrace
    JR
    Louisville, KY
    yeah for me too - mine is mainly a warm-condition issue (i might have already said as much)
  11. Nov 8, 2021 at 9:20 AM
    Jimmyrace
    JR
    Louisville, KY
    radiator left when facing (1,3,5 & then 2,4,6 driver side)
  12. Nov 8, 2021 at 9:24 AM
    16 Bore
    Mines a 2.7 4 banger
  13. Nov 8, 2021 at 9:27 AM
    Jimmyrace
    JR
    Louisville, KY
    been thinking same, but hoping not :/ last fall i did have a leaky water-pump & did not notice for a bit ... thinking could have happened during the low-water event over the course of a few months ... however wasnt driving very much at that time, but also not sure how long that had been happening (until i finally had a crack in the radiator near the inlet (most likely due to over-hot condition) and had to replace - not until then did i notice the leaky water pump only after it would cool down (pressure drop) :facepalm:
  14. Nov 8, 2021 at 10:18 AM
    Jimmyrace
    JR
    Louisville, KY
    yeah that i do not know - perhaps in my FSM ... lemme check ... ahhh couldnt find it
  15. Nov 8, 2021 at 10:49 AM
    #35
    Jimmyrace
    JR
    Louisville, KY
