P0302 after fill up
Discussion in '1st Gen. Tacomas (1995-2004)' started by lovedr79, Aug 13, 2013.
  1. Aug 13, 2013 at 4:04 PM
    lovedr79
    lovedr79 [OP] Active Member
    04 taco 3.4 5spd.
    K&N filter, brush guard and KC lights, TRD
    first post been lurking for awhile. I have a 2004 taco 3.4, 5spd. 220K miles. I get a P0302 only after I fill up, clear the code and its fine until I fill up again. I have changed the plugs, wires, fuel filter, gas cap, #2 injector, swapped coils around. coils all ohm out within spec. I am at a loss. I have run seafoam through the intake a couple times. I have a slight miss at idle but has been like that for years. its not quite a true misfire though. kind of more like rough idle. runs fine otherwise. any other suggestions?
  2. Aug 13, 2013 at 4:06 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    No idea about the code but maybe to try to help the rough idle. Clean the idle air control valve.
  3. Aug 13, 2013 at 4:09 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    it sounds like your gas cap isn't sealing right, do you turn the cap till it clicks a couple times?
  4. Aug 13, 2013 at 4:11 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Or it is left running when fueling :notsure:
  5. Aug 13, 2013 at 4:13 PM
    95 taco
    95 taco Battle Born
    i don't know that that would cause a issue, my cousins 04 pre runner 2.7l didn't throw any codes when he'd leave his truck running while filling up.
  6. Aug 13, 2013 at 4:33 PM
    lovedr79
    04 taco 3.4 5spd.
    Never left running during fill up for several reasons. May try the IAC cleaning next.
  7. Aug 13, 2013 at 7:22 PM
    Aught2TaCO
    Aught2TaCO Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
  8. Aug 14, 2013 at 3:50 AM
    lovedr79
    04 taco 3.4 5spd.
    Thanks! i will try that too. its just bugging the crap out of me. the other thing it started about 15,000 miles after i did the T-belt. runs fine just annoying that i cant make the CEL go away.
