P0302 code Limp mode at 3000 rpms
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trd174x4, Jan 17, 2022.
  1. Jan 17, 2022 at 9:56 AM
    Trd174x4
    Trd174x4 [OP] Active Member
    2017 quicksand trd 4x4 Tacoma
    2017 Tacoma 3.5L v6, 106k miles
    P0302 CODE
    PLEASE HELP
    * I have replaced spark plugs & injectors.
    * I have moved around coil packs.
    (Ripp supercharge coil packs)
    * I have replaced crank sensor.
    * I have check compression in cylinder 2 & 5. Both have good compression. (checked #5 for comparison to #2 and it was the easiest to reach.)
    Still getting the same code P0302.
    I can’t figure this out. I was scared to death that I had a bad valve but the compression is good. And when I restart the truck it runs fine. But once it hits 3000 rpms boom, back into limp mod.
    or if I put it where I shift the gears and let it slowly accelerate it will go to 6000 but once I get to 4th gear and the rpms get around 3000, it’ll do it again, boom back into limp mode.
    It’s baffling.
    Any Help will be greatly appreciated, I really need it. Thank you
  2. Jan 17, 2022 at 9:57 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Did you have the code before all the work you just did?
  3. Jan 17, 2022 at 10:03 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Put the oem coil back onto cylinder two and see what happens.
    shakerhood likes this.
  4. Jan 17, 2022 at 6:36 PM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Good luck. Hope you get it figured out Jordan. You need to find those stock coil packs to rule that out. Or just buy one to put in for that bad cylinder.
    shakerhood and Skydvrr like this.
  5. Jan 17, 2022 at 6:42 PM
    leon03k
    leon03k Active Member
    bad injector
  6. Jan 17, 2022 at 6:45 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    What injectors did you replace?
  7. Jan 17, 2022 at 6:49 PM
    Trd174x4
    I replaced the port injectors
  8. Jan 17, 2022 at 6:50 PM
    Trd174x4
    I just realized the were direct injectors. Shit!
  9. Jan 17, 2022 at 6:50 PM
    Trd174x4
    Port injectors
  10. Jan 17, 2022 at 6:52 PM
    Trd174x4
    I have moved the coil packs around twice now. You still think it’s the coil packs. They are (Ripp supercharger) coil packs
  11. Jan 17, 2022 at 6:54 PM
    Trd174x4
    I haven’t done any work in the truck in over 6 months. So nothing new lately.
    But it has the tune, exhaust, ripp supercharger coil packs with iridium plugs.
    eurowner[QUOTED] likes this.
  12. Jan 17, 2022 at 6:56 PM
    Trd174x4
    I can’t find them, I have moved since putting the new ones on a year ago. And can’t locate them.
  13. Jan 17, 2022 at 6:59 PM
    Tacomike18
    J
    Maybe get some cheap autozone ones and see if it works.
  14. Jan 17, 2022 at 7:08 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    @PapaRee might have beta on this, the direct inectors might "take over" under high load / high rpms on the stock calibration. Unsure tho. Needs a real diagnoses, to be certain.
  15. Jan 17, 2022 at 7:10 PM
    Trd174x4
    Yeah you maybe right. Thank you!
    Skydvrr[QUOTED] likes this.
  16. Jan 17, 2022 at 7:12 PM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Yes. That’s true on the stock tune too. At higher loads and higher rpm, direct injection is 100%.
  17. Jan 17, 2022 at 7:45 PM
    Trd174x4
    Thank you guys so much! I will check the direct injector first thing in the morning.
    anymore ideas would be greatly appreciated.
    Skydvrr and PapaRee[QUOTED] like this.
  18. Jan 17, 2022 at 8:29 PM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    Below are a few snippets from the FSM. You're certainly hitting some of the culprits. Worth watching this video if you're thinking about replacing a direct injector--very advanced DIY...
    If you have techstream and are going to do an injector test, the TSB on how to do it is attached.
  19. Jan 18, 2022 at 4:49 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
  20. Jan 18, 2022 at 5:13 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Get yourself a scanner that records real-time data, or have a professional do it for you. Otherwise you're just throwing parts it and hoping something sticks.
