P0302 or P0136 Advice
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tomato1981, Jan 17, 2020.
  1. Jan 17, 2020 at 9:37 AM
    Tomato1981
    Tomato1981 [OP] Well-Known Member
    So guys I recently got some rough idling on my 02’ 3.4 L V6 Taco. Got the codes it’s a cylinder two misfire P0302. I think I’m gonna go ahead and replace all 6 ignition coils, plugs, and wires.
    However, I’ve had the 02 sensor out for a while P0136 code. It’s been over a yr and never replaced it. Could that be the cause of the P0302 code? Or are these separate incidents??
    thanks and where do you buy your plugs, coils, etc
  2. Jan 17, 2020 at 10:20 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Two separate issues. Replacing coils is probably a waste of money. They virtually never go bad. Plugs, wires, injectors, that's where you start.
  3. Jan 17, 2020 at 11:19 AM
    Tomato1981
    Are ignition coils the same as coil packs? I was under the assumption they’re the same. The printout from AutoZone diagnostic said replace ignition coil. Please clarify for me.
  4. Jan 17, 2020 at 12:18 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Yes, you have 3 coils that fire 2 cylinders each.
  5. Jan 17, 2020 at 12:30 PM
    Tomato1981
    Ok. I’ll start with plugs, wires, and injectors. Any good websites to buy OEM?
  6. Jan 17, 2020 at 12:41 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
  7. Jan 18, 2020 at 7:57 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Always start with the cheapest stuff first. I had a P0303 a while back and it was a cracked plug. I tested the coils with an OHM meter and they were fine, as were the wires. (You test the resistance) The second P0303 ended up being a coil. I tested it again and it was bad. Got an OE coil as the original lasted 15 years and 236k miles. Also got new wires as i was on the originals there too.
