P0303 code HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98_3RZ_NIC, Jan 19, 2023.
  1. Jan 19, 2023 at 9:14 AM
    98_3RZ_NIC
    98_3RZ_NIC [OP] Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    Spark plugs are in order left to right.
  2. Jan 19, 2023 at 10:28 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Okay, I'm liking valves as the culprit here.
  3. Jan 19, 2023 at 12:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    3rd plug looks suspicious.
    And if it’s the #3 cylinder plug, that makes sense.
    I’m not saying it is the plug. I’m just saying, the problem is “evident”.
  4. Jan 19, 2023 at 12:30 PM
    Cucvfan
    Cucvfan Well-Known Member
    Just curious to see how much you paid to get the injectors replaced?
  5. Jan 19, 2023 at 12:54 PM
    tirediron
    One of these things is not like the others... one of these things just doesn't belong...
    It's hard to tell; that could be soot from a leaking injector, or crud from an out-of-whack valve, but it doesn't look like head gasket to me...
    OP, is that #3 plug fouled with fuel (was it wet and smelling of gas when removed) or combustion (dry and sooty/oily)?
  6. Jan 19, 2023 at 3:04 PM
    TnShooter
    Deogee
    STOCK
    I guess it’s time for a leak down test.
    But I’m curious how they checked the injectors and cam to conclude that was the problem?
    You could do a compression test, it’s easier and will show you if a cylinder is “different” than the others.
    Then, do the leak down test on the “different” one. (Cyl 3)
  7. Jan 19, 2023 at 3:08 PM
    98_3RZ_NIC
    im going to pull them again today so I’ll check. I actually remember when I pulled them they did not smell like gas.
  8. Jan 19, 2023 at 3:14 PM
    98_3RZ_NIC
    I did a compression test
    Cylinder 1- 150 psi first try cold
    Cylinder 2- 119 psi first try cold, 90 psi second try cold, 150 psi third try warm
    Cylinder 3- 50 psi first try cold, 60 psi second try warm
    Cylinder 4- 150 psi first try cold
  9. Jan 19, 2023 at 3:16 PM
    TnShooter
    Deogee
    STOCK
    Well, I’d do a leak down test and listen to where it’s leaking from.
    And then, I would go get my money back from the yahoos that misdiagnosed it.
  10. Jan 19, 2023 at 3:24 PM
    98_3RZ_NIC
    I wish I could get my money back but they called me today and said that was the process of elimination they were using to diagnose it. I probably won’t take it back to them. But I’d like to figure out why it’s misfiring. My service advisor from Toyota said to put a couple ounces of oil in the cylinder and wait like 2 minutes and then do the compression test and if the number doesn’t go up then it’s rings and if it does go up then it might be valves. Why couldn’t they do that when I took it in for the diagnosis. What should I tell them?
  11. Jan 19, 2023 at 3:32 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    If they weren't up front with you before the work in terms of diagnosing via process of elimination, I'd file a complaint with the BBB or whatever business authority you have in your state.
  12. Jan 19, 2023 at 3:34 PM
    TnShooter
    Deogee
    STOCK
    At this point, I’d just tell them they were wrong.
    And maybe mention the 4 cycles of a 4 stroke engine.
    I think they checked it for ignition (spark).
    Once they seen spark, they assumed it was fuel.
    That’s not exactly how you should diagnose things.
    It either incompetence, or laziness. Either way, it’s not the way to keep a business “in business”.
  13. Jan 19, 2023 at 3:37 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Process of elimination == we just started replacing parts
    How many miles on it? Have the valves ever been adjusted?
  14. Jan 19, 2023 at 3:39 PM
    98_3RZ_NIC
    273,250 and not to my knowledge. Not in the almost 3 years I’ve owned it.
  15. Jan 19, 2023 at 3:59 PM
    #35
    0xDEADBEEF
    If I were a betting man, I’d suspect a burnt valve. Mine had one at 180k when I bought it.
    A leak down test or measuring valve clearance would be a good move.
    TnShooter likes this.
  16. Jan 19, 2023 at 4:18 PM
    #36
    98_3RZ_NIC
    So if it’s a burnt valve I need all new valves? Or a new head?
  17. Jan 19, 2023 at 4:23 PM
    #37
    0xDEADBEEF
    Probably just one new valve. I took mine to a local head shop. They went through the whole thing, replaced feb valve, new valve stem seals, machined it flat for $427
    But it would be good to make sure that’s it.
  18. Jan 19, 2023 at 4:24 PM
    #38
    TnShooter
    Deogee
    STOCK
    Not necessarily, but you’re getting at least new valves and seats on the cylinder that’s bad.
    At which point, you might as well have the others pulled and inspected. The machine shop will know what is best. And contrary to popular belief, most shops aren’t out get you. They will tell you what needs replaced.
    However, it can sometimes be cost beneficial to just get a new head and return yours as a core.
  19. Jan 19, 2023 at 4:43 PM
    #39
    0xDEADBEEF
    I had a hard time finding a new head when I looked, a lot of shady ones on the internet. The shop was also cheaper by $200
  20. Jan 19, 2023 at 4:46 PM
    #40
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    Thats a bullshit diagnosis
    They didn't properly tested the faulty Injector. I would call BAR.Bureau of Automotive Repair. And have a that technician marry your car
