P0303 code HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98_3RZ_NIC, Jan 19, 2023.
  1. Jan 19, 2023 at 9:39 PM
    #41
    ArizonaBrian
    ArizonaBrian Well-Known Member
    Dang Toyota dealership hiring some knuckle draggers for sure! And to think people pay more because they're the 'experts'. Compression is like 9th grade auto shop level dia'nosing!
    98_3RZ_NIC[OP] likes this.
  2. Jan 20, 2023 at 1:36 AM
    #42
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    They probably charged 2 maybe 3 hours for the diag. And 3 hrs for R&R injector?
  3. Jan 20, 2023 at 5:10 AM
    #43
    98_3RZ_NIC
    98_3RZ_NIC [OP] Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    1 hour diagnosis and 2 hours to replace the injectors and fuel filter.
  4. Jan 20, 2023 at 6:38 AM
    #44
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    The parts canon is NOT a diagnostic tool, and "process of elimination" does not mean spend $5-700 of the customers money on, "we thought" or "it might be". I would file complaints with both the local BBB and with Toyota Corporate. Probably won't get you anything, but hopefully it will annoy them a little bit.
    Assuming that it's a burned valve, then that's not actually a bad result; relatively easy fix, and on an engine like this, it's a good DIY job if you have basic tools.
  5. Jan 20, 2023 at 7:00 AM
    #45
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Lol the service writer telling you to do a wet compression test
    Umm.. shouldn't you guys have done that before putting injectors in it?
    :facepalm:
    That's pretty ridiculous. I'd raise a stink, they pretty much owe you a refund for the diag and the injectors at this point.
    HondaGM, TnShooter and 98_3RZ_NIC[OP] like this.
  6. Jan 20, 2023 at 11:34 AM
    #46
    98_3RZ_NIC
    So who votes new valves? I want the stage 1 head from lce. Only thing is it’s $2,300. How much should it be for Toyota to pull the head and put new valves in? I’m not very mechanically inclined so I don’t want to mess with it.
    HondaGM likes this.
  7. Jan 20, 2023 at 11:39 AM
    #47
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    @Das it mang might remember how much his ended up being at a shop
  8. Jan 20, 2023 at 11:47 AM
    #48
    tirediron
    That seems high to me... I would have thought R&R was about 10 hrs and parts $250-300.
  9. Jan 20, 2023 at 12:08 PM
    #49
    98_3RZ_NIC
    I mean the head itself is 2,300. I’ll see how much they will charge to replace the valves.
  10. Jan 20, 2023 at 12:19 PM
    #50
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I wouldn't give them anymore business until they settle up with you over the botched diagnosis
    HondaGM and 98_3RZ_NIC[OP] like this.
  11. Jan 20, 2023 at 12:22 PM
    #51
    98_3RZ_NIC
    Im going in today when I get off work to talk to the service manager.
  12. Jan 20, 2023 at 12:29 PM
    #52
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    you done a leakdown test?
    b_r_o likes this.
  13. Jan 20, 2023 at 12:30 PM
    #53
    tirediron
    Why do you need a new head?
  14. Jan 20, 2023 at 12:44 PM
    #54
    98_3RZ_NIC
    cost. Might be really close to 2300 to pull the head and replace the valves and components. Just looking at all my options.
    HondaGM likes this.
  15. Jan 20, 2023 at 12:47 PM
    #55
    98_3RZ_NIC
    No. I’m going to ask Toyota to do that free of charge when I go talk to the service manager
    HondaGM[QUOTED] likes this.
  16. Jan 20, 2023 at 12:51 PM
    #56
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Thats good...with 50psi compression its gonna have alot of leakdown somewhere...just get them to tell you where its going and why...
  17. Jan 20, 2023 at 1:47 PM
    #57
    98_3RZ_NIC
    So after the wet compression test I got it up to 90 psi but that’s no better. It’s still gonna leak good somewhere.
  18. Jan 21, 2023 at 12:55 PM
    #58
    98_3RZ_NIC
    So after talking to the GM yesterday they are going to do a boroscope down the in the cylinder to look at the cylinder wall and valves free of charge. I’m going to tell them when I take it back shouldn’t this have been done in the first diagnosis process to rule out the injectors.
    Steves104x4 likes this.
  19. Jan 21, 2023 at 12:58 PM
    #59
    tw0leftskis
    0xApes
    Meta Verse
    Tell the GM that you want a cylinder leak down test
    So that way you know how well each cylinder is sealing. A dry test and wet test.
