P0304 Code Season 12 Episode 01
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bkrdave36, Apr 24, 2025.
  1. Apr 24, 2025 at 8:06 PM
    bkrdave36
    bkrdave36 [OP] Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    Hey All,
    2006 Preruner with 4.0 V6. 457000ish total miles (25,000 miles on rebuilt motor).
    I got the P0304 code. Replaced the coil. Reset code by removing the battery neg cable for about 15 mins. Ran fine for a day.
    Next morning, Starts running like crap, code comes back. Now I replace the spark plug. Runs fine. Turned off the code later that day (when I was away from my house and it wasn't 6 in the morning because my stupid alarm goes off when you reinstall the negative cable.)
    Ran good all the way home from work and to work the next morning (45 mi one way).
    Went to leave work tonight and the damn light comes back on. But it runs fine.
    WTF???
    I'm hoping it will get me to work and back tomorrow.
    Any ideas? Possibly the wiring to the coil? It is the factory original wiring as far as I know. (Where does the wire from the coil end up at on the non coil end? My luck behind the motor on the firewall.)
    Everything appears to be OK since I was all over the top of the motor replacing all the coils. All the spark plugs are new as well.
    Help!
  2. Apr 24, 2025 at 9:03 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you checked if you have the same code?
    An issue on any of the coil circuits would set a P035x code
  3. Apr 24, 2025 at 9:09 PM
    bkrdave36
    Dave
    Wittmann,AZ
    It always comes up P0304. On two separate OBD II readers.
  4. Apr 24, 2025 at 9:10 PM
    bkrdave36
    Dave
    Wittmann,AZ
    By the way, I'm in the Phoenix AZ area and it started getting into the 90s during the day. If that matters.
  5. Apr 24, 2025 at 9:14 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If it only runs rough on a cold start or after sitting for an extended period I'd check it for a headgasket leak by pulling the plug on the offending cylinder, pressurizing the cooling system with a pressure tester, letting it sit several hours or overnight, then looking in the cylinder with a borescope for coolant.
    bkrdave36[OP] and b_r_o like this.
