P0304 Cylinder 4 Misfire - Headgasket Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spanke311, Jan 8, 2017.
  1. Jan 28, 2017 at 6:14 PM
    #81
    spanke311
    spanke311 [OP] Well-Known Member
    Santa Cruz
    05 TRD 4x4 V6 6spd
    Exactly. At least it's not raining on me this weekend. Bolting on the heads in the rain was thrilling
  2. Jan 28, 2017 at 7:22 PM
    #82
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yuck.
  3. Jan 28, 2017 at 7:29 PM
    #83
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Not sure if anyone has mentioned this, but bad head gaskets were a common issue on early 2nd gens. Toyota changed their head gasket design on the 4.0 in like 07-08ish
  4. Jan 29, 2017 at 1:30 PM
    #84
    spanke311
    Santa Cruz
    05 TRD 4x4 V6 6spd
    Some progress.
    Torspd likes this.
  5. Jan 29, 2017 at 1:33 PM
    #85
    Bishop84
    Bishop84 Well-Known Member
    Nice and tidy! Becareful of those lower orings when reinstalling the cover. I like to place some silicone lubricant on them so they slide over the oil pan nicely.
    I also recommend a little extra silicone on the crease from pan to the block. Some help installing the cover is a good idea due to the oil pump needing to be lined up.
    I'd say good luck, but you are very meticulous and will have no issues.
    Torspd likes this.
  6. Jan 29, 2017 at 8:20 PM
    #86
    spanke311
    Santa Cruz
    05 TRD 4x4 V6 6spd
    Thank you for the helpful tips, I definitely review all recommendations before proceeding .
    Man I hope you're right. I literally obsessed for hours preparing things, reading the instruction manual, and then to work as fast as possible with the sealant. I still fought the oil pump a bit even after several dry runs. I really have no way of knowing if the orings stayed put, I can't see them anywhere though so I guess that's good. I used a tiny bit of grease to help stick the orings in place. I put the sealant everywhere practically, wish I could've gotten a picture before I put the cover on but I was in a hurry!
  7. Jan 29, 2017 at 10:05 PM
    #87
    Bishop84
    Sorry for the plural, it's 1 oring from the oil pickup to the pump.
    Looks good~!
  8. Jan 29, 2017 at 11:53 PM
    #88
    spanke311
    Santa Cruz
    05 TRD 4x4 V6 6spd
    I thought the other one you were referring to was the one closer to the top above the water pump. The one at the bottom definitely had me a lot more worried ( there's no way for me to be 100% that it's in place and didn't get smushed out, but I think I gotIMG_7130.jpg it).
    Disappointed I didn't finish today, but had to call it quits for the night:
    uh_salt_rifle likes this.
  9. Feb 1, 2017 at 8:14 AM
    #89
    spanke311
    Santa Cruz
    05 TRD 4x4 V6 6spd
    Finally. I'm not gonna sugarcoat it, that was a pain in the ass. Moment of truth has arrived. Time to go start it and see if it explodes IMG_7223.jpg
    R0dzilla75 likes this.
  10. Feb 1, 2017 at 8:15 AM
    #90
    98tacoma27
    Ben
    Not Beech Creek
  11. Feb 1, 2017 at 9:15 AM
    #91
    spanke311
    Santa Cruz
    05 TRD 4x4 V6 6spd
    I'm having a difficult time getting the oil pump to prime, dammit! I've got the spark plugs back out now and I'm cranking for 20 to 30 seconds and waiting a minute and then cranking for another 20 to 30 seconds so far nothing after five times. Argh. Suggestions?
  12. Feb 1, 2017 at 10:46 AM
    #92
    spanke311
    Santa Cruz
    05 TRD 4x4 V6 6spd
    Never mind, I finally got guts enough to put the spark plugs back in and start the engine. Oil light went off after a few seconds. Vrum vrum! Everything seems to be all good thus far.
    :burnrubber:
    Torspd, Toy4me, AJH387 and 2 others like this.
  13. Feb 1, 2017 at 2:33 PM
    #93
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  14. Feb 4, 2017 at 11:25 PM
    #94
    spanke311
    Santa Cruz
    05 TRD 4x4 V6 6spd
    So I suppose I can conclude the surgery was a success. I still got the P0430 Bank 2 emissions check engine light for the first 2 days after repair which had me worried, but I kept resetting the codes and monitoring the CEL tests with my reader, and yesterday noticed it cleared the tests, so I immediately went to the nearest smog station and about 20 mins later I passed the smog test. Just in time, my registration's up at the end of the month.
    So far, no leaks, no funny noises, no issues. :cool: And there's something satisfying about seeing nearly crystal clear oil on the dipstick.
    For anyone else who may come across this thread replacing a HG with a similar (minimal) mechanical skill set, here's a few things worth noting:
    1) Pull the radiator. The extra space is a very good thing. There's still the air conditioning cooler in front of the radiator that you will need to take care around or protect.
    2) When reassembling the drive belt, put the belt into place before assembling/mounting the fan/pulley onto the water pump. There was not enough space to slide the belt between the crankshaft pulley and the water pump's pulley after assembled, I had to learn the hard way.
    3) Follow the suggestions others posted, like removing the studs near the oil pan, lining up the oil pump ahead of time, take care with the o-rings for the timing chain cover. I personally put sealant on somewhat heavy, applying it to basically all machined surfaces on the timing cover, then hitting the block with sealant at block to head joints, the 3-4 inside circular spots, and generously on the top of oil pan and inside connecting corner.
    4) Study and follow your Haynes/chilton manual carefully. Label everything using sandwich bags and tape. I numbered each timing cover bolt on the picture in the manual and on the bolt itself, then used a black sharpie to mark the bolt number onto the cover itself to help speed up reassembly.
    5) I cleaned my sealing surfaces with a ton of brakeclean, fine steel wool, my Dremel with an assortment of pads, and both non-scratch and regular scotch pads. I plugged my orfices to keep the debris out, swept with magnets to collect wool dust, and flushed and cleaned up thoroughly. I should note the crusted baked on goodness on the pistons practically fell off after a few days of sitting plugged with paper towels just due to the moisture in the air.
    6) Get a master gasket set and replace all encountered.
    7) I struggled to get the crank pulley bolt free, even wasted some money on a pulley holder that didn't work. Since mine's a manual, I put truck in 6th gear and yanked away with 5' worth of breaker and cheater bar. Felt bad yanking counter-clockwise with that much force, but it was the only way for me.
    8) I struggled with disconnecting a lot of my coolant and oil hoses, ripped several in half actually trying to break the bond with pliers. Finally got a good technique going of cramming a small screwdriver between nipple and hose to break them free.
    IMG_6894.jpg IMG_6906.jpg IMG_6910.jpg IMG_6912.jpg IMG_7089.jpg IMG_7090.jpg IMG_7186.jpg IMG_7194.jpg IMG_7198.jpg IMG_7211.jpg
    Torspd and rescuetaco526 like this.
  15. Feb 4, 2017 at 11:41 PM
    #95
    spanke311
    Santa Cruz
    05 TRD 4x4 V6 6spd
    For 10 points, who can name this sensor:
    I apparently broke the clip on this so I had to macgyver a zip-tie to secure it, although I may have pinched the hose a bit with the tie and it sits slightly differently with the tie than with the original clip, but I figure it should be okay... I have no idea what it is though, some sort of air tube sensor thing.
  16. Feb 5, 2017 at 12:18 AM
    #96
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    Glad it all worked out.
    I always cut a piece of cardboard/plywood/sheetmetal/ styrofoam/etc and tape it to the condensor. It wont always stop a something like a screwdriver but it will help keep you from damaging it and adding to the cost of the repair.
  17. Feb 5, 2017 at 12:20 AM
    #97
    Pickeledpigsfeet
    Foothills, CA
    Are you talking about the breather that has the black ziptie?
  18. Feb 5, 2017 at 6:22 AM
    #98
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    Great job on the repair, man! That mystery sensor looks like it is your front differential or transfer case breather. Just follow the hose to the other end to be sure. I'm not for sure on this, but I thought the breather worked better when installed pointing upwards.
  19. Feb 5, 2017 at 7:03 AM
    #99
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Nice work man, without a garage to boot.
  20. Feb 5, 2017 at 3:08 PM
    #100
    spanke311
    Santa Cruz
    05 TRD 4x4 V6 6spd
    Yeah I kept thinking about putting up protection, but ended up just being careful around it. Only did very minor damage to the fins, but if I were to do this again I'd definitely get some styrofoam or similar.
    Yes. So it's a breather, huh? Makes sense, I should've known.
    Cool. I zip-tied it upwards, and it sounds like as long as I didn't pinch off airflow completely with the zip-tie I should be fine. Good.
    Doing the repair outside during the winter months over a gravel driveway was not ideal. But its done. Thanks for this forum and everyone's pointers, very helpful. If I get enough energy to post final parts lists/costs, I will. But to approximate, all said and done, I was in to this about $2,700 + truck rental. Thats about $1,950 to the dealership for parts after returns, $125 to machine shop, and about $600 for coolant, oil, filter, rags, various cleaners, gloves, spark plugs, rags, tools, etc. Although I probably could've gotten a shop to do this repair for marginally more, I feel I did a more thorough job than a typical shop would have, plus I gained all new idlers, tensioners, belt, radiator, hoses, etc. that wouldn't have been otherwise included.
    One final question: how many miles you think I should go until I change the oil again? my gut says maybe around 500 miles then change to get any residual crud out of the engine.
    Torspd likes this.
