P0306 #6 cylinder misfire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GanbaroTaco, Oct 9, 2021.
  1. Oct 9, 2021 at 9:06 AM
    GanbaroTaco
    GanbaroTaco [OP] Member
    2008 indigo ink pearl DCLB
    True trac dif, CAI, MAGNUM back rack, DW fuel pump upgrade, Magnaflow cat back exhaust. Bilstein/OMU 2” leveling kit, LED thru out
    Previous owner informed me he had this problem but it’s NEVER done it to me until now.
    Going around a corner it started to sputter a bit. I let off the gas and it went away. It would come and go and then I had the CEL come on flashing so I pulled over shut it off and it would get better then come back again
    I checked the code when I got home and it was P0306
    previous owner did plugs coils and injector cleaner
    When I first got the truck I did the URD DW fuel pump upgrade and installed an external fuel filter so I plan to change that too and wanted a recommendation for next steps and advice on brand of coils and plugs
    TIA
  2. Oct 9, 2021 at 9:40 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    My recommendation is OE coils and plugs.
    If you want you could pull the plugs on bank 2 (the side with No. 6 cylinder)
    Inspect the No. 6 plug.
    If it looks good, Put that plug in No. 2 cylinder.
    Then swap the No. 6 and No. 4 coils.
    Drive the truck and see if the problem jumps cylinders.
    If so, there’s the problem.
    What you are doing here is isolating the components that were on No.6 cylinder.
    By putting those components on different cylinders, you now know what part likely cause the problem if it shows up on a different cylinder.
    Is it a lot of work?
    Kind of, but it’s free. And it’s better than guessing.
  3. Oct 10, 2021 at 2:51 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Do you know what coils were used to replace the OEM? I've had shitty luck with cheap aftermarket plugs on the Lexus 3.5 engine. Haven't had any go bad on the Taco yet, but have replaced 5 of six on the Lexus. The first two were cheap AA Ignition aftermarket coils and they barely lasted a year. One coil that has lasted is an AutoZone lifetime coil, but it cost $90. The last two replacements have been Yec Flamma, a Japanese aftermarket brand. They are going to two years and have not failed, and cost about $30 (#118F).
  4. Oct 10, 2021 at 4:59 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Do as TnShooter suggested above. Next step would be swapping fuel injectors, then compression test.
    TnShooter likes this.
