P0306 after removing manifold and changing spark plugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cyberwombat, Feb 13, 2025.
  1. Feb 13, 2025 at 8:42 PM
    Cyberwombat
    Cyberwombat [OP] Active Member
    So I had a P0333 and took off the upper/lower manifold to replace the knock sensor harness. Decide its a good tie to put in some new spark plugs (Denso irididum). I put it all back together and I get a P0306. Right off the turn of the key I could tell a cylinder wasnt firing properly - check to ensure wire plug as well seated etc but no go. Any idea what to look for? The harness looks in good condition - wonder if there is another culprit such as me forgetting to hook something back up after the teardown.
  2. Feb 13, 2025 at 8:49 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Did you plug all the injectors back in? 2nd gens will not set codes for injectors so that would be the first thing I would check aside from checking that the spark plug gap didn't get smashed shut during installation.
  3. Feb 13, 2025 at 9:03 PM
    Cyberwombat
    Ok I will look at that in the morning I just pulled the plug out and it has some brown so in the max 5 min runtime I put on it it did fire.
    Dm93 likes this.
  4. Feb 13, 2025 at 9:12 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You sure your on the right one? #6 is on the driver's side rear.
    Nothing got left in the intake ports did it? Seen that happen before too lol.
    TnShooter likes this.
  5. Feb 14, 2025 at 3:56 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Post #2 mentioned gap. On irridium you should never change the preset gap. It damages the coating.
    Havent looked up the code but vacuum or Intake leak?
  6. Feb 14, 2025 at 4:14 AM
    1 Limited Toyota
    California
    08 XRunner
  7. Feb 14, 2025 at 10:37 AM
    Cyberwombat
    Yep, it was the injector. Turns out the electrical harness plug was not well seated. Phew!. Thank you for the suggestion.
