p0325 & p0330 woes.. again
Discussion in '1st Gen. Tacomas (1995-2004)' started by jacky_bubbles, Jun 12, 2013.
  1. Jun 12, 2013 at 9:07 PM
    jacky_bubbles
    jacky_bubbles [OP] Senior Lurker
    Victoria
    Supercharged 1997 Tacoma
    Hey TW
    About a month after dropping the Supercharger on my 3.4 I started getting the infamous p0330 code.. I went all out and replaced BOTH sensors AND the harness only to have the codes p0330 AND p0325 now come in pairs simultaneously immediately after...
    Should I...
    1. Install the URD 7th kit?
    2. Do the GM knock sensor mod?
    3. Hook up my Methanol Injection?
    4. Other
    I'd appreciate any input. I know this issue has many threads, but hopefully over the years we now have a surefire way to rid this amber CEL for good
    -Bubs
  2. Jun 12, 2013 at 9:18 PM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    Definitely start off by running a colder t-sat and maybe colder plugs. My 2nd step would be to invest into the 7th injector setup. You've obviously eliminated the sensors being the issue since the codes still come up
  3. Jun 12, 2013 at 9:19 PM
    cjimenRR
    North Hollywood, Ca
  4. Jun 12, 2013 at 10:00 PM
    jacky_bubbles
    Victoria
    I should have mentioned I'm running the colder plugs and the cooler T-stat already. The 7th with it's ecu piggyback and larger fuel pump are not installed yet though.. think it'll do the trick?!
    thanks RR for the sale link and info
    -Bubs
  5. Jun 14, 2013 at 10:43 AM
    jacky_bubbles
    Victoria
    bump for another opinion or two
  6. Jul 13, 2013 at 11:27 AM
    jacky_bubbles
    Victoria
    Anyone done the GM knock sensor mod in this case?!
  7. Dec 10, 2014 at 8:05 AM
    crisbert
    crisbert New Member
    Hey I am having this exact same problem with my Toyota. Shortly after I installed my supercharger I threw the knock code. I replaced both of the knock sensors and the harness going to the wires. Needless to say, after all that work the code came back, but this time with a companion, the p0300 code. I am at a loss for what to do now and was wondering if you where able to get your code fixed, and if so how.
    Thanks
  8. Feb 1, 2015 at 3:42 PM
    bigbird05
    bigbird05 New Member
    Chattanooga
    97 SR5 Supercharged
    I am having a similar problem. I have replaced the knock sensor and the harness's but then the dreaded p0330 code came on again after about a month. It seems like the code only wants to trip in overdrive at low rpm's any help on what to check/do, Im all out of thoughts. O and I already have the 7th injector from urd and colder denso plugs and the upgraded fuel pump.
  9. Mar 12, 2015 at 9:26 PM
    mikenblue
    mikenblue Member
    College Station, TX
    Thrush Muffler Doug Thorley Headers Deckplate Mod w/ Airaid intake tube and AFE filter OME Lift kit
    bump i have a similar issue. replace both sensors and harness but still have p0330 code. i have the supercharger in with supra injectors, 250lph fuel pump, no piggyback yet
  10. Aug 27, 2015 at 12:39 PM
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Lol guys... does anyone have an answer to this problem? I'm about two fits of rage away from hooking both sensor leads to a single GM sensor screwed to the head somewhere and call it good.
    I replaced both sensors and the pigtail and was EXTREMELY careful not to damage or pinch the wires in any way and I STILL got the codes after I put it together.
    "Help, I need somebody! Help, not just anybody!" :)
  11. Sep 20, 2015 at 7:45 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    My truck does this too after getting supercharged. I tried new sensors, wiring harness, and even an ecu. Nothing has helped. I'm not sure what else to do without dropping lots of money on spare parts.
  12. Oct 13, 2015 at 10:44 AM
    Dixin
    Dixin New Member
    Knock sensors issue... I have replaced both sensors and the wiring harness twice, I ran all the tests from sensors connections to the ECU which all checked out good. I have ordered a second ECU to see if that is the problem.(will repost once i try new ecu) The supercharger has been on for about 89,000km however i have only been owned it for the last 10,000km and this is the first time i have seen P0325 & P0330.
    I had a second wiring harness and 2 extra knock sensors so I plugged them in and had them strapped over to the side of the engine bay so they could not touch anything and i got the exact same 2 codes...
    Anyone have a fix yet?
  13. Oct 13, 2015 at 7:27 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Someone suggested I try a new mass airflow sensor, but I don't know why that would help. New spark plugs didn't help either.
  14. Apr 10, 2016 at 10:07 AM
    1997tacomav6
    Denver
    So I'm having same problem after the supercharger was rebuilt and installed, anyone have a link, or photos, for the GM swap knock sensor installation? Or part number for GM sensor??
  15. May 17, 2016 at 6:18 AM
    1997tacomav6
    Denver
    Well got the new DESNO knock sensors off eBay for 85.00 for the pair
    and installed and running great again, the dealer wanted 250 each,
