P0328 and transmission shifting...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larzzzz, Jul 24, 2017.
  1. Jul 24, 2017 at 5:12 PM
    Larzzzz
    Larzzzz [OP] Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I got the above mentioned code this afternoon and also notice that my transmission will not shift into drive. It will only go as high as fourth on the highway.
    The code is for the bank one knock sensor one high... I assume that to mean it's sensing knocking in the engine.
    Searching, I've seen that rodents have done a job on a number of our trucks' knock sensors. I'm not seeing any signs of that though. Can I see the knock sensors just taking the cover off or do I have use a colonoscope and go deep...
    I only used branded gas and this last fill up was shell vpower when is filling up the boats gas can. Other threads mentioned bad gas as a possibility, but this is a pretty busy station I went to, so I'm gonna discount that as the issue.
    What else might cause that code
    Any
    Rossstaco612 likes this.
  2. Jul 24, 2017 at 7:35 PM
    elliott3
    elliott3 Unknown
    in the ozarks
    99 xtracab 4x4 03 dcsb 4x4
    Under the intake. Not a bad job. I replaced both sensors and harness because you dont want to do it twice.
  3. Jul 25, 2017 at 4:46 AM
    Larzzzz
    Larry
    MA
    How long did it take? Any out of the ordinary tools needed? I'll be doing this after work...
  4. Jul 25, 2017 at 5:07 AM
    elliott3
    elliott3 Unknown
    in the ozarks
    Toyota says you have to pull a head to get the water pipes out. My heater hose one was leaking so I cut the brackets off and could then get them out. Reroute heater hose around engine and good to go. 3 1/2 hours all done. Parts all together were around 400 for gaskets O rings sensors and harness. If not dealer says 18 hours!
  5. Jul 25, 2017 at 6:30 AM
    gearcruncher
    Canadain bumper technician
    What year is your truck ? what size engine ?
  6. Jul 25, 2017 at 2:12 PM
    Larzzzz
    Larry
    MA
    The light went out this afternoon and it shifts all the way up now.
    @elliott3 damn... Haven't had to tear into this motor until now, maybe. $400., ugh. Oh well, it is what it is.
    @gearcruncher this 4.0 motor is from an 05 that had 79k. The 06 original had 238k and the head gasket finally popped.
  7. Jul 30, 2017 at 5:46 PM
    Larzzzz
    Larry
    MA
    Ok... This code has been off and on the past few days.
    Anybody buy knock sensors off of fleabay? Really don't want drop 4 bills right now...
  8. Jul 4, 2022 at 9:39 PM
    Rossstaco612
    Rossstaco612 New Member
    '09 Taco TRD OR
    @Larzzzz , I'm having the same issue with my 09 Tacoma. The Check engine light comes on with the same code, and when I go on the interstate it wont shift up to 5th, and also the light turns off so it's only an intermittent issue. What did you find for a solution for yours?
  9. Jul 5, 2022 at 1:51 PM
    Larzzzz
    Larry
    MA
    I found the harness connector loose at the back of the engine. This was after a motor swap I had done.
    I had a couple codes pop up after the swap. Both were relatively easy fixes, but were somewhat difficult to locate and identify as the culprit(s)
    b_r_o and Jimmyh like this.
  10. Jul 5, 2022 at 1:55 PM
    Rossstaco612
    '09 Taco TRD OR
    How'd you find/diagnose the loose harness connector? Where's that at specifically?? Thanks.
  11. Jul 6, 2022 at 9:28 AM
    Larzzzz
    Larry
    MA
    I went in search of... Passenger side, by the head is where the connector is.
