P0330 knock sensor looking to fix fast
Discussion in '1st Gen. Tacomas (1995-2004)' started by Drtbker, Apr 26, 2018.
  1. Apr 26, 2018 at 11:37 AM
    Drtbker
    Drtbker [OP] Well-Known Member
    2019 Cement Tacoma OR 6speed
    So right now I need to get tabs for my truck and I have to get an inspection. I've heard of splicing the wire at the ECU. How would you go about this or is there a link that explains this?
    Thank you!
  2. Apr 26, 2018 at 2:14 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I've never heard of that one. I assume your v6?
  3. Apr 26, 2018 at 2:18 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    I have had good luck splicing them at the connector located at the top of the timing cover. In my case I just made a jumper and connected the two knock sensor leads together. I did it on the pig tail side of the connector.
  4. Apr 26, 2018 at 2:21 PM
    Pickeledpigsfeet
    Foothills, CA
    I used vamp connectors cause I was testing to see if I had a lazy KS and wanted to be able to remove it. Would be easy to solder and do it clean enough that noone would notice.
  5. Apr 26, 2018 at 2:34 PM
    Drtbker
    Yeah all I'm trying to do is pass emissions so I can get my tabs lol then I'll actually replace the sensor when I have more time
  6. Apr 26, 2018 at 2:35 PM
    Drtbker
    Yeah v6. I've heard some people splicing them to the working sensor to trick the ecu in thinking they both work so I can get rid of the code to pass emissions
  7. Apr 26, 2018 at 2:42 PM
    Drtbker
    The picture, is that the knock sensor wire harness right there?
  8. Apr 26, 2018 at 5:42 PM
    spinyard
    spinyard Well-Known Member
    Doesn't this bypass the knock sensor all together? Better hope you dont get a batch of bad AM/PM gas :)
  9. Apr 26, 2018 at 6:15 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    nope. just reads both banks off one sensor. bypassing the sensors pulls all the timing putting truck in a limp mode state.
  10. Apr 26, 2018 at 6:23 PM
    spinyard
    Ah nice, they're really not that hard to replace just have to pull the intake manifold and buy the $100 sensor :)
  11. Apr 26, 2018 at 8:00 PM
    Pickeledpigsfeet
    Foothills, CA
    Yes, those two blue connectors are breaching the insulation on each ks wire. To the right of that greay stock connector is the replacable pig tail. just mimic that pic and later when you have time you can pull the intake and replace the pig tail and both sensors.
  12. Apr 26, 2018 at 8:25 PM
    devinzz1
    devin
    2023 aclb trd or mt
    90% of the time its the harness thats failed actually. they harnden up and corrode under the manifold.
  13. Apr 27, 2018 at 4:40 PM
    spinyard
    yep, when I did my 1992 - 2003 3.4 conversion I got all the way done and I had this pesky error, you're right it was the harness that was crispy!
  14. Apr 27, 2018 at 9:13 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    I mean it's not really as easy as you just made it sound. You have to pull the upper plenum, lower plenum, and the intake manifold. And all the things that need to be removed in order to remove those things.
    Also yes the jumper thing works fine. I stripped a little of the wires used a little bridge wire right at the ECU. Both banks running off 1 sensor... until the other sensor popped too. Boost does that to the wimpy factory knock sensors. You need to find a EWD for your year truck to get the wires right- toyota liked to change them every few years.
  15. Apr 28, 2018 at 7:37 AM
    spinyard
    True, but it is the correct way to repair it, Toyota would fix It that way.
  16. Apr 29, 2018 at 4:31 PM
    Drtbker
    Yeah and this was something I needed done quick because i needed tabs and in Washington they make you do emissions before. definitely going to fix it the right way when it starts getting nice and I have more time
