P0335 CODE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 009597, Jul 1, 2019.
  1. Jul 1, 2019 at 9:29 AM
    009597 [OP] New Member
    SHANNON
    2007 TACOMA TRD
    P0335 CODE
    1. I have an 07 Tacoma V6 that has a P0335 code: Crankshaft position sensor circuit malfunction.
      This code appeared only when I stepped on the gas hard to pass a vehicle at hwy speeds (90 kmh) while under a load (towing a cargo trailer) The transmission went from Drive, to 1st or 2nd gear to pass this vehicle. The engine warning light has since disappeared and has not come back on since. Was this just a warning sign for me pushing the truck too hard, or is it something I should seriously get checked out? It's going to take over 3 hrs labour just to get at the crankshaft sensor to test!
  2. Jul 1, 2019 at 9:32 AM
    Bishop84
    Bishop84 Well-Known Member
    We've seen this when older cars are pushed that don't see high revs very often. Possibly there's carbon build up or worn ignition.
    When is the last time you changed the spark plugs, they have short intervals for replacement.
  3. Jul 1, 2019 at 9:39 AM
    SHANNON
    2007 TACOMA TRD
    Why do you think spark plugs or ignition has anything to do with a crankshaft position sensor?
  4. Jul 1, 2019 at 7:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Code P0335
    DTC Detection Conditions:
    • No CKP sensor signal to ECM while cranking (1 trip detection logic)
    • No CKP sensor signal to ECM at engine speed of 600 rpm or more (1 trip detection logic)
    Trouble Areas:
    • Open or short in CKP sensor circuit
    • CKP sensor
    • Sensor plate (CKP sensor plate)
    • ECM
    More Data to check here:
    https://www.customtacos.com/tech.ol...06toyrm/06toypdf/06rmsrc/rm2006ta/0050031.pdf
