P0340 and P1300
Discussion in '1st Gen. Tacomas (1995-2004)' started by 99RojoTaco, Nov 24, 2024.
  1. Nov 24, 2024 at 7:49 AM
    99RojoTaco
    99RojoTaco [OP] Well-Known Member
    1999 Red Tacoma (manual 4x4 5vzfe)
    Still trying to figure this headache out, many people have had similar issues but I can’t find a solution from the problem I’m having. I found one forum for first gens on these codes and the dude just ended up replacing his starter after doing absolutely everything else and then it solved it. Think I’m in the same boat? It has thrown cam and crank position sensors, as well as the generic p1300 which means igniter circuit 1. Any help would be appreciated my truck runs fine but is very challenging to get started, no stalling or touch idiling. Also recently did my timing belt and all that jazz not long ago but it was still doing it before. Started a little while after I got done with the knock sensors but not instantly
  2. Nov 24, 2024 at 9:16 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    been a ford engine mechanic for 30+ years, no idea how replacing the starter is going to fix this...
    Time to see a professional that knows the product, dealer....
  3. Nov 24, 2024 at 9:23 AM
    Glamisman
    Glamisman Well-Known Member
    The guy who "fixed' it by replacing his starter makes sense to me. The camshaft position sensor is the type of sensor that requires a minimum rpm in order to produce a signal that the PCM can understand. In addition to this there is a minimum voltage required at the PCM and other sensors in order for them to do what they have to do. Usually a 10.5 - 11v under load, i.e. cranking, is too low. It might be enough to turn the motor over but not fast enough for the "system" to work resulting in extended crank time, hard start etc.
    The battery, the battery cables and starter need to be checked, looking at them isnt good enough, preform a voltage drop test on all posative and negative battery cables and see if you can get an amp draw and rpm test readout on the starter, you might have to take it out and down to an auto parts store that has the equipment for that.
    For the electricly curious the cam sensor is a variable reluctor sensor (2 wire) whereas a 3 wire sensor is a hall effect sensor. The difference between them is one signal is saw tooth and the other, the 3 wire is a square wave type signal.
    BatteredTaco likes this.
  4. Nov 24, 2024 at 9:51 AM
    slater
    San Diego
    Well ide do some serious testing, amperage draws / load testing, before shwagging a starter at it..
    Test battery too & cables...
    But if a starter is $100 & you want to roll the dice again, go ahead..
    Theres plenty of fords with similar systems & never seen a starter cause cam related codes...
  5. Nov 24, 2024 at 11:29 AM
    Glamisman
    This is 1999 vintage system and it is an apples oranges comparison. Maybe, maybe Toyota had a handful of manufacturer specific PIDs outside of OBDII. Last time I looked at a new Superdurty with Fords IDS there were what, 400 + PIDS?
  6. Nov 24, 2024 at 7:43 PM
    99RojoTaco
    Sounds good thanks a lot, I’ll do some testing tmrw or Tuesday and let you know what I find out, any more testing I should make sure I do in order to figure out if the starters working alright?
