P0345 code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by duckcmdr, May 25, 2009.
  1. May 25, 2009 at 2:18 PM
    duckcmdr
    duckcmdr [OP] If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    I the past weel or two my truck has been starting funny... I turn the key all the way and i hear the starter click once then silence then it engauges, some times its 2seconds or 10 sec. Well today it was taking a long time 30 - 40 sec and the CEL came on and the code was P0345 which i guess is the cam shaft position sensor. I cleared the code and proceeded on the truck is running fine, just the starting issue. Then it would not start... it took about 15- 20 tries to start and the code came back on.. So i got her home from the shore and getting ready to figure this out. Anyone have this happen before??
  2. May 25, 2009 at 2:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Never had it happen, But this should help you:
  3. May 25, 2009 at 2:42 PM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    Thanks For the Info Chris. I going out to see if its going to be a loose connection or did i screw it up at the Wharton scratch and splash. I think if it were a problem with the actual cam shaft she would be running good...? Hate electrical issues
  4. May 25, 2009 at 4:01 PM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    any idea if thisnwould be covered under the powertrain warrenty??
  5. May 25, 2009 at 4:24 PM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    dropped the skid hoping to see the starter and wtf where is it? do they look different in tacos?
  6. May 25, 2009 at 4:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes, It will be covered under the power train warrenty. The starter is on the Driver side, rear of the engine. I sent you a PM.
  7. May 26, 2009 at 3:40 PM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    well this is how it went down at the stealership.... told them about the code and the guys response was " Great a customer that thinks he knows it all" :eek: I was like WTF ! I told him not to shut the truck off because it will be hard to get started. He shut it off and was like "well you were right it didn't start back up". Yeah no shit why do you think i'm here. Anyhow they said the starter went bad and is not covered under warrenty.. Ok what about the code well it looks like your truck has been under water and there are wet contacts on some wires under the hood.
    I didn't have time to fight that starter so i had them do it at the price of 472.12.... well 95.50 of that was them telling me that the code P0345 yeah no shit thats what i said...
    checked for the price of the starter and it was around 200 so i guess it wasn't that bad... MMMM Yeah that will help me sleep better...
    Thanks again chris for your help>
  8. May 26, 2009 at 4:18 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Could have rebuilt the starter too, theres a few shops around that still can do that kinda stuff..... lot cheaper.
  9. May 26, 2009 at 4:22 PM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    yeah i don't really have the time nor did i feel like fighting the removal of these startes they are jammed up in there. Its just stupid that a starter is such a process they should be easy.
  10. May 26, 2009 at 4:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    BS!!!!!!
    Call Toyota corperate! That starter SHOULD HAVE BEEN COVERED!!!!
    I want to KICK THE GUY IN THE BALLS!!!!!!
  11. Nov 20, 2016 at 3:40 AM
    mvang87
    mvang87 Member
    Mark
    2007 Slvr Tacoma
    Oldman EMU Lift ARB Front Bumper Morimoto LED Bulbs
    I just ran into the same issue with my 07 Tacoma. Did the starter ultimately fix the problem?
    - Mark
  12. Dec 18, 2018 at 6:37 AM
    bradforj
    bradforj Well-Known Member
    TN
    07 4x4 v6 TRD Sport
    2012+ Front End Swap 2014 steering wheel swap w/audio and BT controls 2014 power window controls 2014 lower center dash and radio bezel 2014 a/c controls Auto-dimming mirror Heated side mirrors Turn signal side mirrors Backup camera DNX890HD head unit Kenwood speaker system Kobalt slim toolbox In-channel Ventvisors N-Fab running boards
    I have just gotten this code and starting issue with my 07. To all others who have experienced this problem, did replacing the starter permanently resolve the issue?
  13. Dec 18, 2018 at 8:01 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  14. Jan 6, 2019 at 1:45 PM
    mvang87
    mvang87 Member
    Mark
    2007 Slvr Tacoma
    Yes, it did for me.
    bradforj[QUOTED] likes this.
