P0351, P0353, P0355, entire bank of ignition coils failing at once?
Discussion in 'Technical Chat' started by Buttermilker, Dec 23, 2022.
  1. Dec 23, 2022 at 12:53 PM
    Buttermilker
    Buttermilker [OP] Well-Known Member
    Danny
    Bishop, CA
    '16 ACOR
    Sierra pinstriping Eibach stage 1, 3 leaf AAL
    Im throwing these codes and it seems unlikely that the entire passenger side of ignition coils would fail at once but maybe i'm wrong and they tend to fail together? Or am i right and it seems likely it would be something else going on? if so, any suggestions to what it may be?
  2. Dec 23, 2022 at 12:57 PM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    Do as pressure leak down test. I would suspect a head gasket.
  3. Dec 23, 2022 at 1:32 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Those are coil circuit codes, they have nothing to do with engine mechanical.
    OP I'd look for rodent damage in the engine harness.
  4. Dec 30, 2022 at 4:38 PM
    Buttermilker
    Danny
    Bishop, CA
    '16 ACOR
    If anyone in the future finds this it turned out to only be a burnt out coil on cylinder 3. Once I replaced that coil the codes for all three cylinders went away. Why were the other codes getting thrown? Who knows. Took Toyota 2 weeks to get me my coils, so I probably worth having a spare one for when one burns out you're not stuck waiting.
    jaceon likes this.
  5. Jan 14, 2023 at 12:22 PM
    jaceon
    jaceon Member
    Jace
    2009 Tacoma TRD
    @Buttermilker .. Having this exact issue. Appreciate the info. I shall start with a new coil. I assume coils A C and E are the passenger side correct?
  6. Jan 14, 2023 at 3:06 PM
    Buttermilker
    Danny
    Bishop, CA
    '16 ACOR
    Yea
    jaceon likes this.
  7. Jan 18, 2023 at 6:08 AM
    jaceon
    jaceon Member
    Jace
    2009 Tacoma TRD
    Bought an $18 aftermarket coil.. replaced cylinder 3.. same issue.. tried cylinder 5 instead and so far so good :fingerscrossed:. Thanks
    Buttermilker[OP] likes this.
