P0402 excessive flow
Discussion in '4 Cylinder' started by duggravs, Jun 3, 2014.
  1. Jun 3, 2014 at 10:25 AM
    duggravs
    duggravs [OP] Active Member
    ricky
    torrance, ca
    stock 2004 prerunner
    airbox mod
    I have a 04 3rz the check engine light came on with code p0402 (excessive flow) I cleaned the iac and the egr (with carb cleaner). The egr seemed ok. It moved up n down when I added vacume to it. And after I installed it. I added vacume to it. And the motor stalled. (Isn't that what's suppose to happen?) all the vacume lines are good. for some reason the check engine light came on again. Should I look at something else? Or should I just replace the egr?
    I checked a couple forums. I can't seem to find a straight answer what it could be.
  2. Jun 5, 2014 at 6:17 PM
    duggravs
    ricky
    torrance, ca
    airbox mod
    someone must of had this problem besides me.
  3. Jun 5, 2014 at 7:41 PM
    Ninj
    Ninj Well-Known Member
    Ninja
    New Hampshire
    2011 Super White TRD Off-road SR5 6 Speed
    URD True Cold Air Intake URD MAF PnP Version (Very easy to install) Full Custom Exhaust 2.5" Stainless Steel Pipe, Doug Thorley Long Tube Ceramic Coated Headers, 2 stock catalytic converters (2 cat deletes), X Pipe, Dual Flowmaster Super 44s, 2 Jones 18 inch stainless steel tips, Full exhaust exits before rear passenger wheel like the SVT Lightning (I have Krisxone’s 09+ ECU adapter so I can go URD Boosted, Tested and working) 3 Inch Ultimate Toyotech lift (Silver Painted Coilovers) with Old Man Emu Leafs (No add-a-leaf here)
  4. Jun 5, 2014 at 7:42 PM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    I believe this is one of the more common codes. Could be as simple as an exhaust leak or bad o2 sensor.
    Scratch that, dyslexia got the better of me. I was thinking p0420
  5. Jun 5, 2014 at 7:51 PM
    duggravs
    ricky
    torrance, ca
    airbox mod
    I just noticed that the r port on my throttle body was going to the vacuum switch valve. And not to the r port on the vacuum modulator. And the vacuum modulator hose was going to the R port on the throttlebody. Let see if that makes a diffrence.
    I'm going to be kicking my self in the ass if that was the problem.
  6. Jun 5, 2014 at 7:52 PM
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Be sure to post up if it was the issue! :cheers:
  7. Jun 5, 2014 at 8:10 PM
    duggravs
    ricky
    torrance, ca
    airbox mod
    I will.
  8. Jun 10, 2014 at 11:32 AM
    duggravs
    ricky
    torrance, ca
    airbox mod
    I can confidently say that I fixed the problem. It was two vacuum hoses that were switched around. I've been driving around for a couple days now with no check engine light.
    Thanks for all the hell everyone.
