P0408 Trouble Code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reymundo88, Jan 2, 2015.
  1. Jan 2, 2015 at 12:23 AM
    Reymundo88
    Reymundo88 [OP] Well-Known Member
    Rey
    05 Tacoma TRD Off Road
    Installed K&N Cold Air Intake
    My check engine light recently came on and had it checked out at an auto parts store, they gave me the trouble code P0408 but couldn't explain what was the cause of this or even possible solutions. I have a '05 tacoma double cab with 139k miles, I was wondering if anybody else has had this same problem and what you did to fix it, thanks in advance for any advice.
  2. Jan 2, 2015 at 1:15 AM
    ChollosWorld
    ChollosWorld Member
    South Louisiana
    11 TRD Off-Road 4x4
    It could be an EGR (Exhaust Gas Recirculation) valve issue. I had this issue on a '99 Chevy and had the valve/solenoid replaced which fixed the issue.
    More information on the subject with repair options:
    http://www.obd-codes.com/p0408
  3. Jan 2, 2015 at 2:21 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Funny I don't see that code listed in the service manual... ???
    I also do not see an EGR Valve for the Tacoma.
    The closest code I see is a P0418 for the air injection system.
  4. Jan 2, 2015 at 9:38 AM
    Reymundo88
    Rey
    I will get it scanned once again, perhaps they gave me the trouble code of somebody else's vehicle. Either way thanks again for the advice. If I find the solution I will post it.
  5. Feb 16, 2015 at 3:03 AM
    Reymundo88
    Rey
    Just to follow up on the issue that I had and that trouble code that appeared on my truck, turns out that the secondary oxygen sensor on the drivers side was the issue. I can't remember whether or not that P0408 was the code that appeared when my friend Vargas put on the snap - on scanner but it did show that it was really slow on responding and also was fluctuating alot more than the other three oxygen sensors.
