P0418 Code Help!!!
Discussion in 'Technical Chat' started by stupedaso, Jan 10, 2012.
  1. Jan 10, 2012 at 4:13 PM
    stupedaso
    stupedaso [OP] New Member
    Los Angelas
    SR-5 Tacoma
    I have a 06 Tacoma 2.7 4 cyl. I just bought a scanner because I have some issues with the vehicle not being able to pass California smog test. One reason I know of is the seal on the fuel pump housing leaks when I fill up my tank so I need to address that issue. I just put the scanner in the obdii and I got this error code P0418 It relates to the air injection pump. What can I do to fix it myself or at least begin diagnosing the issue?
  2. Oct 12, 2012 at 7:18 AM
    TT2010
    TT2010 New Member
    Cape Coral FL
    Tacoma 2010 4x4
    Do not look at the instruments, the pump is needed when it is cold and running for 15-20 seconds, and does not affect the operation of the engine. The price of the dealer $ 1,500. I do not advise buying a used, it is not collapsible, and they can not replace the brush.
