P0418 DTC Code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Viper32, May 3, 2012.
  1. May 3, 2012 at 4:25 PM
    Viper32
    Viper32 [OP] Active Member
    Okay guys just bought another Tacoma a 2007 SR5 Reg Cab 4 cylinder Prerunner. It had a engine light on it when I bought it. Anyways the code is P0418, I have looked at several diagrams and all but need a little help on what to check exactly and how to check. Please help......
    Viper
  2. May 3, 2012 at 6:05 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
  3. May 3, 2012 at 7:35 PM
    Viper32
    Thanks I guess I should have posted it is a 4 cylinder...... I will look this over see if it helps..........
    Viper
  4. May 9, 2012 at 5:48 AM
    Viper32
    Whew after allot of painless time figuring this out. It was the harness end that connects to the air pump. It had a bad terminal, looked lioke it was broke off and was not making good contact. I do not know if you can buy just that end does anyone know?
    Viper
