P0420 and P0430
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma414, Jan 1, 2020.
  1. Jan 1, 2020 at 2:37 PM
    Tacoma414
    Tacoma414 [OP] Well-Known Member
    Cody
    Agua Dulce
    06 PreRunner SR5 4.0L
    Flowmaster Exhaust 2" spacer lift 09 Tails blacked out Black headlight mod 6000k HIDs/Foglight mod Fog Light Mod 20" LED Light Bar Behind Grille Billet Grille Color matched mirros, doorhandles and bumper 5% tint all around Pioneer 4300dvd 2 10" kicker CVRs Alpine speakers Dome light: Blue LED Map light: White LED
    So it sounds like both my CATs are bad, I'm in SoCal near Anaheim and I'm going to sell the truck because im up to 235k miles on it. Know where or what company I can use to get them done?
  2. Jan 1, 2020 at 2:44 PM
    Dan 77
    Dan 77 I leave my bikes outside
    Dan
    San Antonio
    06 DCSB TRD Sport 4X4
    Kings and TC UCAS 01 DCSB 4X4 Totaled All-Pro bumper, mile marker winch
    Is P0420 definitely a bad cat? I have the same code.
  3. Jan 1, 2020 at 2:48 PM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    No it’s not necessarily a bad cat. It could be something as simple as a leak from a bad exhaust gasket. P0420 codes can be a pain to diagnose
  4. Jan 1, 2020 at 2:50 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Try switching your sensors to confirm first.
    I do have a stock set of OEM manifolds in the garage if they are hard to find.
  5. Jan 1, 2020 at 2:51 PM
    Tacoma414
    Cody
    Agua Dulce
    Reason i think its a bad code is because i had a misfire a while back and replaced the spark plugs, and then both codes popped up so that's what i was assuming it was.
  6. Jan 1, 2020 at 2:53 PM
    Bishop84
    Bishop84 Well-Known Member
    I always warn others, p0420/430 is rarely anything but cats. Especially on Tacomas, you'll see people suggest exhaust leaks, or sensors but its the cats.
    The misfire likely accelerated their end, the cats don't like misfires or overfueling.
    b_r_o likes this.
  7. Jan 1, 2020 at 2:54 PM
    Tacoma414
    Cody
    Agua Dulce
    So replace the sensors first? And then go from there?
  8. Jan 1, 2020 at 3:06 PM
    goldentaco03
    Liam
    NJ
    Check for leaks first. It’s the cheapest thing to do and gaskets are only a couple bucks if that’s what it is. Then test your sensors instead of going straight to replacing them cause they’re a bit pricey. There’s a bunch of videos on YouTube of how to do this. If all that checks out then test your cats, again there’s videos and articles online on how to do this. The most common method I’ve seen is using an infrared thermometer and checking the temps at the inlet and outlet of the cats.
  9. Jan 1, 2020 at 3:07 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    If you only have one bank error then switch sides with the sensors to confirm if your problem is actually on that bank or just a bad sensor if it shows on the opposite bank after switching.
  10. Jan 1, 2020 at 3:08 PM
    Tacoma414
    Cody
    Agua Dulce
    Both bank 1 and 2 are bad
  11. Jan 1, 2020 at 3:10 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Check for signs of soot that indicate exhaust leak around the manifold.
  12. Jan 1, 2020 at 6:25 PM
    Tacoma414
    Cody
    Agua Dulce
    So if everything checks out to be the CATs, where is a good place to get them. Got a shop that'll do 1500 installed for both, not OEM. Or he said 300 to install if i bring him both
  13. Jan 1, 2020 at 6:58 PM
    FJBub
    FJBub Well-Known Member
    Doug
    2010 Tacoma PreRunner 2015 Tacoma TRD Off-Road 2008 V8 4Runner
    $1500 is a good deal. I had mine replaced on my FJ a couple years ago for about $1800 using MagnaFlow cats. CEL light hasn't come on since. Toyota wanted about 4K to replace them.
  14. Jan 1, 2020 at 6:59 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Not sure where “agua duice” is but for OEM is he talking about bringing in two cats or complete manifolds?
  15. Jan 1, 2020 at 7:00 PM
    Tacoma414
    Cody
    Agua Dulce
    Agua Dulce is a little north of Santa Clarita, CA and he said 1500 for the manifold cats.
  16. Jan 1, 2020 at 7:03 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I have OEM cats on stock manifolds but my manifolds won’t fit your truck. I can cut off the cats on one end and they can just weld them up to your manifolds. Mine are off a 2014 with secondary air injection pipes which is why they won’t bolt up. I thought I saw yours was an 06.
  17. Jan 1, 2020 at 7:09 PM
    Tacoma414
    Cody
    Agua Dulce
    Yeah mines an 06, so would that mean you need new CATs then?
  18. Jan 1, 2020 at 7:09 PM
    Tacoma414
    Cody
    Agua Dulce
    Im fixing them to sell so whatever clears the code and passes smog I'm good with
    zippsub9 likes this.
  19. Jan 1, 2020 at 7:12 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    No, the cats are the same, just the recirculating piping is different where the manifold mates up to the block. They can just weld on these cats to your manifold after cutting off your bad cats.
    I don’t need/want cats up front. I run long tube headers, JFR y-pipe, 3” collector, magna cat back, resonator to a Dodge Ram 1500 muffler. I don’t have to deal with CARB.
  20. Jan 1, 2020 at 7:13 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    These will work then, totally committing that it is your cats and not just a freak occurrence that both sensors failed at the same time.
