P0420 and P0430
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma414, Jan 1, 2020.
  1. Jan 1, 2020 at 7:38 PM
    Tacoma414
    Tacoma414 [OP] Well-Known Member
    Cody
    Agua Dulce
    06 PreRunner SR5 4.0L
    Flowmaster Exhaust 2" spacer lift 09 Tails blacked out Black headlight mod 6000k HIDs/Foglight mod Fog Light Mod 20" LED Light Bar Behind Grille Billet Grille Color matched mirros, doorhandles and bumper 5% tint all around Pioneer 4300dvd 2 10" kicker CVRs Alpine speakers Dome light: Blue LED Map light: White LED
    How much for the CATS then. Im assuming it is because its unlikely they went at the same time and it threw the codes when i had the misfire
  2. Jan 1, 2020 at 7:47 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I’ll shoot a PM tonight. I got company right now. However, make sure you confirm with them to weld them on first. Just make sure they understand you will bring in a set of OEM cats to be welded onto your mufflers and get their cost. I think the 300 they quoted you may have been to simply bolt up another set of complete manifolds.
  3. Jan 1, 2020 at 7:49 PM
    Tacoma414
    Cody
    Agua Dulce
    Okay will do, its a muffler shop so i think the 150 was for welding or bolt up
  4. Jan 2, 2020 at 4:27 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I had the p0420 code. It turned out to be the gasket connecting the cat to the Y pipe on the passenger side. Check all the joints for soot. That's how I found mine.
    Dan 77 likes this.
  5. Jan 2, 2020 at 5:36 AM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    What he said!! I had p0430 and turned out it was exhaust leak at gasket, replaced a few months ago, no more code!
  6. Jan 2, 2020 at 5:39 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    You can also use soapy water on a cold start up to check for leaks at those gaskets. It helps if someone else starts it since the soapy water won’t last long.
  7. Jan 5, 2020 at 11:40 AM
    Tacoma414
    Cody
    Agua Dulce
    Been busy at work but ill do that tomorrow. Just worried about the misfire i had and the codes popping up right after that happened.
