P0420 came back!
Discussion in 'Performance and Tuning' started by ETaco23, Apr 18, 2010.
  1. Apr 18, 2010 at 8:43 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    The problem with that is the fact that when he hooks up to the smog machine, he would fail guaranteed without the catalytic convertor. The O2 sim will turn off your light sure, but if there is a bigger issue here all you're doing is masking it and leaving yourself prone to other issues. Just informing.
  2. Apr 19, 2010 at 7:27 AM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    So its probably best just to replace the cat. If it is bad. So how does one know which cat is bad? If I do the diagnostic will it tell me?
  3. Apr 19, 2010 at 7:39 AM
    memario1214
    Colton
    Missoula, MT
    I would have to say yes, your best bet would be to replace the cat. It is uncommon, but they do go bad. When I took the rear ones off of my truck, there were pieces of screen from my front cats in it. I honestly don't believe that a diagnostic will tell you which one is bad if either of them are, but I know nothing about what I diagnostic tests. Before you do anything drastic, I say you take it to that friend of yours and see what he says.
  4. Apr 19, 2010 at 10:13 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Most muffler shops have cats for cheap. I won't be oem but it'll work.
  5. Apr 19, 2010 at 7:16 PM
    ETaco23
    Evan
    PNW
    Yeah, Im ganna be calling him tomarrow and hopefully he can look at it, and find out whats wrong. But Im hoping its not my front cat, because I we had to weld that new flange to it for my TRD headers, and that was a pain! He wont be happy If we have to do it again!:rolleyes:
  6. Nov 27, 2010 at 8:07 AM
    el contrador
    el contrador Member
    André
    Montreal, Quebec, Canada
    03, Tacoma double cab 4wd
    Original a to z
    Hi!!
    I've been reading A LOT on this P0420 problem and found out a few good thing you might like to know!!!
    I lot of people have the same problem that we do, some changed everything related to emission system. Cats, o2 sensors, MAF, MAP, Temperature Sensor and still had the light coming on!!
    On thing that not a lot a people think of checking is the Ethanol rating in the gasoline they use!! Toyota tacoma are set to use Gas with less then 10% ethanol... So what i did is I empty my tank and filled it back with ethanol Free Gasoline, unplug the battery to erase the codes and Guess what, no more light...
    The problem with ethanol is that it doesn't burn like regular gas at all and our O2 sensors do not reconised the exhaust gas so your check engine light turn on!!!
    I was using Gasoline that had 12% Ethanol and didn't know it!!
    Try that and let me know what happens
    Thanks
  7. Dec 9, 2010 at 1:24 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    Do not get a magnaflow! I bought one that was guaranteed to pass OBDII. It did... for a week. I gutted it and bought a sim from URD. I pass emmisions everytime provided I do not have a leak.
    When I installed my headers I removed the first cat (closest to motor) I never threw a CEL. The 1st one is a pre-cat I believe. This may or may not work on yours.
  8. Dec 9, 2010 at 1:32 PM
    memario1214
    Colton
    Missoula, MT
    ^^^ Your setup on a First Gen is slightly different than us second gen guys... But you are partially right! lol
