P0420 --> cat conv
Discussion in 'Technical Chat' started by hokietruck, Oct 15, 2010.
  1. Oct 15, 2010 at 10:37 AM
    hokietruck
    hokietruck [OP] New Member
    Northern Va
    02 TRD 3.4 - 170k
    I can see we can file this topic under commonly searched/quoted; forgive me for my lazyness, but i'm at work and want to get in and out:
    Real quick:
    2002 TRD 3.4L 6 170kmiles.
    Dealer stated w/ that code - rec replacement of cat converter assy - $2900 parts and laber.
    I have emissions in 1 yr, so i'll ride it out; all the while thinking that quote is ludicrous.
    Thoughts/Recommendations.
    Thanks.
  2. Oct 15, 2010 at 11:12 AM
    biscuits87
    biscuits87 Well-Known Member
    Will
    St J, VT
    10 TRD Off Road V6 6-speed
    Avid Light Bar
    Advance Auto Parts has a direct fit cat converter for $225. If you look around you can probably get it cheaper or even go with a universal fit one under $100.
  3. Mar 1, 2011 at 9:35 PM
    The Munster
    The Munster I like turtles!!!
    Lance
    Moody AFB, GA
    DON"T BUY AFTERMARKET.. aftermarket ones just aren't efficient enough for toyotas standards. you'll buy those MIL light comes back on then your buying factory cats... replace the post cat o2 sensor(bank * sensor 2) crap from the destroyed cat contaminates the sensor
  4. Mar 1, 2011 at 9:40 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Just to let you know, I had that same code with my 02 Taco and it ended up being my o2 sensor's....
    Have you checked those? they usually will go bad before a cat. will.....
