P0420 code help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Racinmason03, Mar 14, 2016.
  1. Mar 14, 2016 at 5:17 PM
    Racinmason03
    Racinmason03 [OP] Member
    1999 Green Tacoma
    dynomax cat back exhaust
    I have a 99 Tacoma 2.7l 4x4 and I keep getting the p0420 catalyst efficiency below threshold bank 1.
    I have replaced
    -both oxygen sensors
    -coolant temp sensor
    -all exhaust gaskets
    I have had this problem for over a year now. It only comes on when I go on a long drive 30 miles plus. Could this be egr valve or bad converter? I don't think the converter is clogged any help would be appreciated
  2. Mar 14, 2016 at 5:47 PM
    1988Mercedes
    1988Mercedes Well-Known Member
    CHARLES
    ARKANSAS
    2020 AG PRO MT
    converter. Fixed my 420
  3. Mar 14, 2016 at 5:50 PM
    Vang Toua Moua
    Vang Toua Moua Well-Known Member
    Vang Bang
    Visalia, CA
    05 Silver Tacoma 2.7, Access cab, 5 lug
    Custom front bumper and rock sliders, glasspack muffler, shorten exhuast, abs killswitch, roof light bar, rear e locker.
    I'm going thru the same thing. I still can't find it either.
  4. Mar 14, 2016 at 7:23 PM
    Tjsingle26
    Tjsingle26 Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    I had an exhaust leak at the flange when I got that code. Cut the bolts off, replace the gasket, new bolts
  5. Mar 14, 2016 at 8:36 PM
    HelenaTDI
    HelenaTDI Well-Known Member
    Montana
    2000 Tacoma TRD
