P0420 Code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hennessy3300, Feb 29, 2024.
  1. Feb 29, 2024 at 10:37 AM
    hennessy3300
    hennessy3300 [OP] Well-Known Member
    Trying to get my P0420 code to go away. I am going to start checking for any leaks and replacing the O2 sensor. Is this the left or right side downstream o2 sensor? 2005 sr5 v6. Rockauto has Denso sensors, these ok to use?
  2. Feb 29, 2024 at 10:41 AM
    tylerdietzenbach
    tylerdietzenbach Well-Known Member
    Tyler
    2018 Tacoma TRD Sport
    Passenger side
    Denso o2s are really good.
    Chances are you are having leaks or a bad cat. Join the club. Lol
  3. Feb 29, 2024 at 10:43 AM
    hennessy3300
    220K on the original sensor. guess it can't hurt to try.
    inwood customs likes this.
  4. Feb 29, 2024 at 10:44 AM
    tylerdietzenbach
    Tyler
    Save the old one. Unlikely to be bad. You could test it if you can read the readings off the pcm via a scan tool etc
  5. Feb 29, 2024 at 10:51 AM
    hennessy3300
  6. Feb 29, 2024 at 10:58 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I swapped the sensors side to side (cable is diff length, but it worked after releasing from support). Issue did not follow the O2 sensor. Took it in and I had a bad cat.
    Anteupp and tylerdietzenbach like this.
  7. Feb 29, 2024 at 11:02 AM
    RockfordTaco2006
    RockfordTaco2006 Well-Known Member
    Alexander
    2006 Toyota Tacoma TRD Off Road 4x4
    2 Inch Lift
    I had the P0420 monthly on and off. I changed the PCV valve and it's been three months since the light came on. OEM PCV is cheap $8 or less....I also bought the cheater fowlers but my 02 sensor was seized so I haven't gone that route. Good Luck!
    fatfurious2 likes this.
  8. Feb 29, 2024 at 11:05 AM
    YF_Ryan
    Kent, WA
    Maybe you tried this, but I had to soak one of mine for a couple days with PB blaster and then finally ran the truck to get it nice and hot, and I was able to break it loose.
  9. Feb 29, 2024 at 12:51 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    This is my issue. Currently its off. :fingerscrossed:
  10. Feb 29, 2024 at 12:57 PM
    GearHead899
    GearHead899 Well-Known Member
    Justin
    Ocean View, NJ
    11' Black X-Runner, 06' RR X-Runner
    At the mileage, its common that the cats are just bad. Throw a o2 sensor spacer on the rear o2 and you will be good to go. Thats what I did for a while. Ended up just putting long tubes on and getting rid of the cats all together
    fatfurious2 and tylerdietzenbach like this.
