P0420 Code
Discussion in '1st Gen. Tacomas (1995-2004)' started by NC2001Tacoma, Dec 6, 2024.
  1. Dec 6, 2024 at 5:17 PM
    NC2001Tacoma
    NC2001Tacoma [OP] Well-Known Member
    Getting this code on my 2001 3.4 Tacoma 4 door. I have read it could be the O2 sensor or the cat.
    Which 02 sensor should be replaced?
    I have 2 cats,which one could be failing or both?
  2. Dec 6, 2024 at 5:44 PM
    Glamisman
    Glamisman Well-Known Member
    Check for exhaust leaks first. You can do this yourself with a shop vacuum. Take the exhaust hose off the vacuum and put in on the exhause pipe, seal it and spray a soapy solution around the O2 sensors and the exhaust connections and look for bubbles.
  3. Dec 6, 2024 at 6:13 PM
    phoforbreakfast
    phoforbreakfast Well-Known Member
    Usually P0420 is the O2 sensor which is downstream/after the cat. Either cat could fail but definitely check for exhaust leaks. Sometimes rust will create holes around the welds, etc.
  4. Dec 6, 2024 at 6:18 PM
    NC2001Tacoma
    So I'm basically blowing air into the exhaust?
  5. Dec 7, 2024 at 4:14 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    After leak check possibilities are... well... exhausted..., gas cap seal is somewhat common. So much so Toyota has an updated gas cap. Its a good place to start. o2 extenders or antiffoulers help fight overzealous EPA programmed emmision levels. They will often elimate po420 codes or at minimum reduce them. These codes are common on weak, but not bad catalyst performance. This + curtain driving conditions can cause a cat "under performance standard" or low oxygen saturation po420 issues. All common Toyota po420 issues.
  6. Dec 7, 2024 at 5:38 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    For what it’s worth, my 420 code was exactly what it said it was… bad cat. Did everything before new exhaust, o2 sensors the works. It was just a bad cat.
    NC2001Tacoma[OP] likes this.
  7. Dec 7, 2024 at 7:32 AM
    Glamisman
    Yes, pressurizing the exhaust, this test works.
  8. Dec 14, 2024 at 9:12 PM
    Bahamayellow
    Bahamayellow Well-Known Member
    2002 tacoma sr5
    I am getting the weak catalyst as well. Im sure its the cat also but will check the o2 sensors first only in bank 1.
  9. Dec 15, 2024 at 6:04 AM
    1 Limited Toyota
    California
    08 XRunner
    Weak cat does not mean bad cat. Maybe meating the over zealous EPA numbers that reality won't back. Even brand new o.e.m. cats can throw a po442/po443 under certain conditions.
    Unless dead, o2 sensor replacement with new is actually worsening the issue as the readings are now MORE sensitive. The exact opposite of what you want. Weak cat + very active o2 = tattle tell trouble. Thats why o2 spacers tend to work.
    Ever notice the guy that bah humbugs anything but a new cat usually aimed the "new o2" parts cannon at the repair first? Sure a new expensive cat will always work but why not try a cheap extender fix first?
    Funny thing is these guys tend to buy aftermarket cats. A year or twor later the minimal metals cheap aftermarket use are worn out... often worse than the quality "weak" o.e.m. they thru out.
  10. Dec 15, 2024 at 6:13 AM
    NC2001Tacoma
    Got a chance to look at things under the Truck and found that the gasket between the rear cat and exhaust pipe has broken. There was a 1/4 gap missing out of the gasket. Going to replace that and see what happens.
    SecureIT2021 and ztwatson like this.
  11. Dec 15, 2024 at 6:14 AM
    noodles93
    Charleston, SC
    In my case, the cat looked fine when I looked through the downpipe end but when I removed it completely, the other side was completely shredded up/cracked apart. I ended up putting a $300 walker cat in and it has held up a couple years so far.
    SecureIT2021 likes this.
  12. Dec 16, 2024 at 3:18 PM
    1 Limited Toyota
    California
    08 XRunner
    Before or after the cat?
    Ez enough fix exhaust leaks can and do set these codes?
    Always fix the obvious first either way. Hope that gets it
  13. Dec 16, 2024 at 5:24 PM
    NC2001Tacoma
    It was the outlet on the rear cat that connects to the exhaust pipe.
  14. Dec 16, 2024 at 5:38 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    I had a bad weld (exhaust leak) at this same location cause my P0420 code.
  15. Dec 16, 2024 at 5:42 PM
    NC2001Tacoma
    Hope it's whats causing mine.Going to get under the Truck tomorrow and do a little more looking around.
    ztwatson[QUOTED] likes this.
  16. Dec 17, 2024 at 2:08 AM
    1 Limited Toyota
    California
    08 XRunner
    Toyota updated the gas cap as it was common evap related leak/issue. Cheap possibility. Think of it as maintenance.
