P0420 code
Discussion in '1st Gen. Tacomas (1995-2004)' started by benhalf, Jan 23, 2025.
  1. Jan 23, 2025 at 6:59 AM
    benhalf
    benhalf [OP] New Member
    Ben
    Hello all. I have a 2001 Tacoma pre runner. (3.4L, 5 speed automatic) 151,000 miles.
    I’ve owned it for roughly a year. It has been flawless and I have kept up with normal maintenance. Lately, I’ve been getting a recurring code (P0420) It comes up every ≈350 miles. It reads something along the lines of “catalyst efficiency below threshold bank one.” It has a custom cat-back exhaust that I didn’t install but looks professionally done. Truck is fine otherwise. I’ve noticed my exhaust has smelled richer, and my mpg has declined. (Getting about 50 less miles out of a tank) (it’s also around 0 degrees where I live.)
    Suggestions on how to move forward?
    It sounds like it could genuinely be the cat, but I’ve heard to start by looking at the 02 sensors or even cleaning the mass airflow sensor first.
    Thank you for any suggestions!
  2. Jan 23, 2025 at 7:03 AM
    02hilux
    Planet: EARTH
  3. Jan 23, 2025 at 7:05 AM
    Glamisman
    Glamisman Well-Known Member
    At the top of the 1st gen forum there is a "sticky" section. In this section there is a post all about the P0420. Read it and if you have any questions after that dont hesitate to ask them.
  4. Jan 23, 2025 at 10:08 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Likely an exhaust leak.
  5. Jan 23, 2025 at 10:59 AM
    benhalf
    Ben
    Makes sense, thank you gentlemen. I’ll try to fix any exhaust leaks and go from there!
  6. Jan 23, 2025 at 10:10 PM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Po420 is low catalyst efficientvy. Standards set by EPA that even new cats under certain condition can not meet.
    Exhaust leaks are most common starting point checks. The worst thing you can do for po420 is new sensetive o2 sensors. You want to "numb down" the sensors. Cheap o2 sensor spacers more often than not cure the issue completely. But only if your cat is still working 1/2 way decent. And it probably is.
  7. Jan 24, 2025 at 8:51 AM
    Glamisman
    As a PSA... The EPA got "smart" around 2008 ish and they forced manufactures to incorporate what I was told is an "crazy Ivan" strategy. Every so often the PCM will force a lean or rich condition for a fraction of a second just to see how ALL of the 02 sensors react. This is a pass/fail type strategy. A shrouded O2 sensor will not react to a known rich/lean condition and if it does this often enough, it will set a P0420 AND set a P0420 permanent code. A permanent code can only be cleared after fixing the problem and by driving a minumum distance AND having a certain number of drive cycles, usually 15 cylces without any codes being set.
    1 Limited Toyota likes this.
  8. Jan 25, 2025 at 2:46 AM
    1 Limited Toyota
    California
    08 XRunner
    Interesting
  9. Jan 25, 2025 at 11:42 AM
    woad4
    woad4 Well-Known Member
    2003 Tacoma Xtra Cab
    3rzfe
    I know some people check for exhaust leaks with this trick:
    - Using a shop vac, reverse the hose, so the vacuum blows air not sucks.
    - Shove vacuum hose in your tailpipe with a shop rag around it to create an (airtight ish) seal.
    - Turn shop vac on, spray soapy water on exterior of exhaust pipes and look for big bubbles.
    JustADriver and Moonrman like this.
