P0420 is it always a bad cat?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Spicy__taco, Jun 28, 2023.
  1. Jul 3, 2023 at 10:29 AM
    #41
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    You can definitely drop the tank without removing the bed. Removing the bed does give you easier access to all of the hoses and connectors though. If your truck has lived in the rust belt for any amount of time it's pretty likely you'll have to replace the straps. That was the case for me at least
  2. Jul 3, 2023 at 10:40 AM
    #42
    Spicy__taco
    Spicy__taco [OP] Well-Known Member
    2002 radiant red Tacoma SR5
    Stock
    Now when you replaced your gas tank, were you able to find a complete parts list for all the hoses that were required and the new gaskets and seals? I can probably find them online if not.
  3. Jul 3, 2023 at 10:59 AM
    #43
    CrustyTaco
    Todd
    Louisville, KY
    I used the parts diagrams on partsouq.com for reference, but these were the hoses and gaskets I used. There are a few other evap hoses that can be replaced with fuel line, the two pictured below were formed hoses, so I wanted to buy the OEM part.
  4. Jul 3, 2023 at 11:13 AM
    #44
    Spicy__taco
    Stock
    Awesome, thanks. I'll start collecting all the parts I guess. I'm hoping that defouler will keep the O2 sensor fault away long enough to pass emissions.
  5. Dec 7, 2023 at 11:27 PM
    #45
    Rnmiker
    Rnmiker New Member
    1997 Toyota Tacmoa
    My engine light was on and that code popped up. I changed my spark plugs, air filter, oil, and oil filter. I drove it around for about 100 miles and the check engine light turned off and I passed smog. 1997 Tacoma
  6. Dec 8, 2023 at 9:19 AM
    #46
    ab_1280
    ab_1280 Well-Known Member
    Alan
    2000 Silver Tacoma TRD 4x4 3.4L V6 X-Cab Manual 413K
    Thanks for all the info posted here, very helpful.
    I live in CA and have a 2000 3.4v6 4x4 manual with 401,000 miles with a persistent p0420 code. If I clear it, it comes back in about 500 to 1000 miles. Cats were replaced with aftermarkets at about 240,000 miles. Then replaced the rear one again at 280974, due to it having issues. (code p0420). They chased an exhaust smell in the cab for a while, finally getting rid of it. My wife said she could still smell it faintly, however.
    Other replacements:
    Mass air sensor at 383889
    Vac hose 378052 (p0171 code)
    Rear O2 sensor 344564
    Lots of general maintenance all through its history, I've had it for 380,000 miles.
    I just got a quote for $3500 to replace both cats and O2 sensors. I need also to do a timing belt change, with the usual work associated with that. Probably looking at $5k to $6k for all this. Truck runs FANTASTIC and is otherwise in good shape. But it won't pass smog coming up in June '24.
    Any thoughts on whether something else than the cats might be throwing the p0420 code? I'm hoping to not need to put 5-6k into a truck that runs great.
    Thanks for any help!
  7. Dec 8, 2023 at 11:07 AM
    #47
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    That is strange that it comes back after being cleared for so long. My P0420 code would come back within 10-20 miles everytime I cleared it without fixing the problem. My issue was a leak between the rear cat and rear O2 sensor. If you haven't done a leak test yourself I'd suggest that. It also sounds like you should try replacing your air/fuel sensor before the first cat if you haven't tried that. Do you have a bluetooth scanner where you can look at live data to see what it shows?
  8. Dec 8, 2023 at 11:16 AM
    #48
    ab_1280
    Alan
    Thanks, I'll try a leak test. I should also get a bluetooth scanner like you mentioned. Do you recommend a certain model?
  9. Dec 8, 2023 at 2:37 PM
    #49
    ztwatson
    Milwaukee, WI
    I splurged for the Bluedriver bluetooth scanner (~$100) but you can get ones for around $20-30 I believe.
