P0420 keeps coming back
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomainthesun, Dec 30, 2018.
  1. Dec 30, 2018 at 9:22 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Yup the heater circuit is what fails for me on the front. I get P0135 when my front fails. Just replaced my front yesterday. It lasted 8 years, Denso. My stock one lasted 9 yrs. Of course Denso is what I replaced it with again.
    cruiserguy and eon_blue[QUOTED] like this.
  2. Dec 30, 2018 at 9:26 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    You could bypass the rear sensor. Then remove the cats. Then ecu only needs the front sensor for AFR adjustments.
  3. Dec 30, 2018 at 9:28 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Yeah I had a P1036 for the rear...looked like it was covered in soot when I took it out. But I had pretty bad lean issues that killed my cats about a year ago so I think that sensor was on borrowed time. Replaced it with a Denso as well and all is good again.
    I could tell something was up before the code came on because my AFR gauge in closed loop was holding at +/-14.0 rather than 14.7 like it should be. After I replaced the sensor it went back to normal.
    zero4[QUOTED] likes this.
  4. Dec 30, 2018 at 9:29 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Boosted life. :thumbsup:
    eon_blue[QUOTED] likes this.
  5. Dec 30, 2018 at 10:20 AM
    tacomainthesun
    tacomainthesun [OP] Well-Known Member
    02(sold) 17 trd or
    Why would he replace the sensor and say that it wasn’t reading before the fix then?
  6. Dec 30, 2018 at 10:26 AM
    tacomainthesun
    02(sold) 17 trd or
  7. Dec 30, 2018 at 10:26 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Because 'mechanics' say and do dumb shiz all the time.
  8. Dec 30, 2018 at 10:27 AM
    Bishop84
    Bishop84 Well-Known Member
    It was likely reading, p0420 doesnt trigger on bad o2's. But I'm dumb.
    o2 sensors are the most commonly misdiagnosed item by DIY mechanics.
    tacomainthesun[OP] likes this.
  9. Dec 30, 2018 at 10:28 AM
    eon_blue
    Azusa, CA
    I would get ones designed specifically for your truck...that one has an o2 sensor bung in a spot different from where our's goes
  10. Dec 30, 2018 at 10:30 AM
    cruiserguy
    Elijah
    SEKS
    That's what I was getting at, replaced it without truly diagnosing the issue. Happens all the time. I was agreeing with you, I think. Lol
  11. Dec 30, 2018 at 10:30 AM
    tacomainthesun
    02(sold) 17 trd or
    :mad::censored:
  12. Dec 30, 2018 at 10:32 AM
    Bishop84
    Haha :dancingbacon:
  13. Dec 30, 2018 at 3:25 PM
    rogerman
    rogerman Well-Known Member
    Roger
    HNL 808, SPN 670
    2000 Tacoma SR5 V6 4wd 5speed
    I have the P0420 code right now. My truck is a CA emissions but I live in Hawaii and there is no emission testing. If I were to buy non CARB cats, would it make the P0420 code go away? I've been looking around some people say that non carb cats on CA trucks still trigger the P0420 code.
  14. Dec 30, 2018 at 3:32 PM
    eon_blue
    Azusa, CA
    Hmm that's a good question I dont know for sure, I want to say there shouldn't be a difference as far a the ecu is concerned...But there could be. I know there's know difference in o2 sensors between different emission spec trucks so I don't know why the cats would be any different.
