P0420
Discussion in '2nd Gen. Tacomas (2005-2015)' started by John.desantis82, Dec 6, 2015.
  1. Sep 6, 2017 at 2:52 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
  2. Sep 6, 2017 at 3:33 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I had this same code after an engine swap. It turned out to be the donut gaskets connecting the Y pipe to the manifold. I barely noticed a black stain on the flange. New donut gaskets from the dealer and I was good to go after I installed them.
  3. Sep 6, 2017 at 4:14 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Because Commi-fornia. Ultra high emissions rating.
  4. Sep 6, 2017 at 6:22 PM
    vram74
    vram74 Well-Known Member
    05 Prerunner SR5
    So hypothetically speaking, one non CA resident could delete the two converters forward of the O2 sensors and suffer no ill effects?
  5. Sep 6, 2017 at 7:16 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    No, the O2 sensors will detect what is upstream. If you delete the forward cats the O2s will throw error codes. Anything behind the O2 sensors the truck will not know about, but isn't strictly legal. Some states may check with inspections, others don't.
  6. Sep 6, 2017 at 7:18 PM
    vram74
    05 Prerunner SR5
    Thats what I meant to say. We don't have an inspection law where I am and there will still be two cats on the truck.
    I don't plan to delete them unless they become a problem down the road, anyway.
  7. Sep 6, 2017 at 7:30 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    O2 sim for the fronts.
    With the advancement in sensors and systems, the old anti foulers barely work these days, unless lady luck is on your side.
    Works great on my old Bimmer though. :woot:
