P0420
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03taco, Feb 29, 2020.
  1. Mar 4, 2020 at 8:11 PM
    #41
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    The computer reads exhaust gas going into catalytic converter from B1S1
    And reads exhaust gas going out of catalytic converter from B1S2. Data determines the fuel trims as well as the catalytic converters operating status. Thus the term " Catalytic converter operating below predetermined efficiency" P0420
    eon_blue likes this.
  2. Mar 4, 2020 at 8:16 PM
    #42
    Black DOG Lila
    Virginia
    If you're lucky you can pull the black rubber plug under the passenger side floor and pull the connection out rather than pulling rocker panel cover and carpet under passenger seat.
  3. Mar 4, 2020 at 8:18 PM
    #43
    eon_blue
    Azusa, CA
    Make sure to get the proper Denso branded O2 sensors and beware of cheap priced fake ones online. These trucks don't fare well with aftermarket sensors
    Black DOG Lila likes this.
  4. Mar 4, 2020 at 8:18 PM
    #44
    03taco
    03taco [OP] Well-Known Member
    Alex
    2004 Taco
    Never Ending Project
    only denso one
  5. Mar 4, 2020 at 8:21 PM
    #45
    eon_blue
    Azusa, CA
    Not sure if that was a question lol, but yes...Denso is the OEM brand for Toyota sensors. A lot of other companies make sensors for these trucks as well but they usually don't work well and you'd likely see the problem persist
  6. Mar 4, 2020 at 8:23 PM
    #46
    03taco
    Alex
    2004 Taco
    yea i only get the denso ones
  7. Mar 4, 2020 at 8:25 PM
    #47
    Black DOG Lila
    Virginia
    eon_blue is right
    Buy from DensoProducts online for exact replacement. I've seen sensors that you have to splice the wires and wrong connectors, incorrect wire ga. and length. Even screw in sensors with adapter plates from other than DensoProducts online. Save yourself some misery, pay the extra $8
  8. Mar 5, 2020 at 6:15 AM
    #48
    Old n' slow
    Old n' slow Well-Known Member
    Oak Island, N.C.
    2000 Tacoma 2.4 5 speed flare side
    replace the front one first, see what happens......you can always replace the back one later.
  9. Mar 5, 2020 at 7:40 AM
    #49
    03taco
    Alex
    2004 Taco
    Front one is brand new
  10. Mar 5, 2020 at 7:57 AM
    #50
    Old n' slow
    Oak Island, N.C.
    Oops.....I missed that.
    You were smarter than me. I had code and replaced both, it still came on constantly. Took out new Denso rear O2 and code went off for a long time then finally came on again recently .....finally did the $4.00 capacitor/ resistor trick and now out for months......URD next ?????
  11. Mar 5, 2020 at 7:59 AM
    #51
    03taco
    Alex
    2004 Taco
    That's what I will be doing... if this doesn't work then the urd simulator
  12. Mar 5, 2020 at 8:00 AM
    #52
    eon_blue
    Azusa, CA
    You need a new cat(s) or you have an exhaust leak
  13. Mar 5, 2020 at 8:20 AM
    #53
    Old n' slow
    Oak Island, N.C.
    100% tight exhaust. Cats (California model $$$$$) are slowly dying, exit temperatures are below threshold, probably too much low speed , short hop driving.
    Just trying to postpone the major expense on a truck that’s driven 3-4,000 miles a year.
    cruiserguy and Black DOG Lila like this.
  14. Mar 5, 2020 at 8:34 AM
    #54
    Black DOG Lila
    Virginia
    I switched to non Ethanol gas and CEL has been off for the last 8 months.
    What's in your Tank?
  15. Mar 5, 2020 at 8:51 AM
    #55
    Old n' slow
    Oak Island, N.C.
    The cheap stuff......$2.03 a gallon.
    if it eventually comes on again I might invest in some Cataclean or the Scotty Kilmer paint thinner method ; )
  16. Mar 5, 2020 at 8:54 AM
    #56
    Black DOG Lila
    Virginia
    TruFuel is $20 gal Cataclean $20 pint
    Same stuff different pricing.
    Old n' slow[QUOTED] likes this.
  17. Mar 5, 2020 at 9:04 AM
    #57
    Old n' slow
    Oak Island, N.C.
    TruFuel......thanks, I’ll write that down so I don’t forget. I’m also old n’ forgetful : (
    P.S. I included the $2.03 price per gallon just to tease the California guys ; )
  18. Mar 5, 2020 at 9:12 AM
    #58
    Black DOG Lila
    Virginia
    I gotcha
    Tacomas don't do well on 10+% Ethanol is why I asked what's in your tank
  19. Mar 5, 2020 at 10:23 AM
    #59
    eon_blue
    Azusa, CA
    I went through this myself a couple years ago, my cats burned out thanks to a lean condition I had with the supercharger because the previous owner didn't do any fuel modifications to accommodate it.
    Got the P0420 code and eventually figured out it was my front cat that was bad, needed to pass smog so I could get registered. Called Toyota and they wanted nearly $3,000 to install 2 OEM cats on my truck, I politely said 'F that' lol. I ended up getting two CA approved Magnaflow cats installed by a local exhaust shop. I passed smog after that with flying colors and just recently passed again last month. The Magnaflows were $600 installed, front and rear
    I guess my main point is, you don't have to replace your CA cats with OEM cats, you can get CA approved ones in the aftermarket for much, much cheaper. Magnaflow is widely regarded as the best option
  20. Mar 5, 2020 at 1:26 PM
    #60
    03taco
    Alex
    2004 Taco
    TacomaEli likes this.
