P0430 Code... What should I do?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sar, May 21, 2010.
  1. May 21, 2010 at 4:16 PM
    sar
    sar [OP] Well-Known Member
    Newfoundland, Canada
    2018 Tacoma TRD Sport DCSB Manual (on order)
    Well my check engine light on my 2005 TRD Offroad Taco has been on for quite some time now and I was told by the dealer 25000 kilometers ago that it was the catalytic converter. Just read the code myself tonight with a OBD2 Diagnostic Tool and confirmed it. I know I should of had this rectified by now but finances just didn't allow it at the time so easy on the criticism please lol.
    I have spent a couple hours now reading all the posts on the topic (ie. o2 sensors vs. cats etc.) I do not believe that I have any symptoms other then poor gas milage which I started to experience at around 80k. The CEL came on at 159k and I am at 176k now.
    Should I just relace the oem cat at the dealer? I was looking at going with an entire new exhaust system as well (magnaflow). Perhaps this would be the better choice and bang for the buck? What would I need from magnaflow in addition to the exhaust? I assume two magnaflow cats, and the o2sim from urd? Also, the o2sensors seem to be corroded pretty bad. Should I replace them as well? To simplify... what exhaust components would you guys/gals buy if you were in my shoes with a truck that has 176000k on it?
  2. May 21, 2010 at 4:18 PM
    The_Dude
    The_Dude Well-Known Member
    keelometurs?
  3. May 21, 2010 at 4:21 PM
    sar
    yes... kilometers
  4. May 21, 2010 at 4:24 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i think i'd stick with an oem cat and then go with whatever exhaust you like. aftermarket cats dont work real well on these trucks.
  5. May 21, 2010 at 4:38 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    This came from a different forum:
    Hello All,
    I just received a letter in the mail from Toyota oxygen sensors. They stated that they have had a lot of complaints about the 2 oxygen sensors before the catalytic converter. This would be Number 1 Oxygen Senor, Bank 1 and Number 1 Oxygen Senor, Bank 2. They said that they are going to warrant these parts up to 7 years or 90,000 miles because of the check engine light coming on with the indication that the oxygen sensors are bad. I have replaced mine already, but they will reimburse if you have documents showing that your replaced them and that you own that vehicle.
    If you did not receive a letter like I did, I would suggest contacting Toyota:
    Toyota Motor Sales, U.S.A, INC.
    Toyota Customer Experience, WC 10
    19001 South Western Ave.
    Torrance, CA 90501
    The P0430 code like you said could be O2 sensors or the cats. I'd try the sensors first, they're cheaper than cats (especially if you can get Toyota to replace them for free).
  6. May 22, 2010 at 4:42 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I had the exact same problem last year. Luckly they took care of it right away.
  7. May 22, 2010 at 4:53 AM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    You could also try spacing out the rear o2 sensor with a spark plug anti-fouler. They come 2 in a pack and you drill on out to 1/2 inch. Place that one on the sensor. Then screw both of them into the pipe. It slows down the flow across the sensor thus not tripping a code. You can get them at your local auto store. It's a cheap test and or fix. GL
    Thechief86 likes this.
  8. May 22, 2010 at 7:33 AM
    HerNameIsLucy
    RIP Lucy.
    Nifty stuff! Wouldn't have worked for me when mine threw the infamous code, mine was the heater circuit blown open. :mad: I actually spent some time thinking about how I could put a big resistor across the heater circuit leads to fool the ECU, but ended up replacing the sensor. Not cheap little things. :(
  9. May 22, 2010 at 7:48 AM
    tacobox
    Yeah the anti-fouler trick is to confirm cat codes. If it's the sensor ,that will need to be replaced.
  10. May 22, 2010 at 8:04 AM
    sar
    Should I or do I have to replace both sensors at the same time? Or just on the side with the bank 2 cat? Should I just get the oem sensors or go with aftermarket? What sort of cost would I be looking at? Thanks!
  11. May 22, 2010 at 8:12 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    honestly....i'd replace both at the same time. dont buy from dealer tho..........and do not go aftermarket. aftermarket ones will crap out very quickly.
    get denso oem ones from rockauto.com...........way cheaper than the dealer....and u get a tw discount.
  12. Jun 11, 2010 at 4:49 AM
    sar
    Thanks for all the suggestions guys. I have been away for a while and now that I am back I want that CE light gone and will try the things mentioned. One thing that I have noticed is that after I reset the code it does not come back on again until I remove the gas cap and fill the truck up with gas. It then comes right back on. Would that provide any clues as to O2 sensor vs a cat?
  13. Jun 11, 2010 at 5:02 AM
    98tacoma27
    Ben
    Not Beech Creek
    A code P0430 may mean that one or more of the following has happened:
    • The catalytic converter is no longer functioning properly \
    • An oxygen sensor is not reading (functioning) properly
    • There is an exhaust leak
    I would state at the bottom of this list and work my way up. Look for leaks, repair if any are found. Replace the sensors, next. And if that doesn't work, move on to the CAT. If you get new sensors, make sure you get the DENSO OEM sensor. Rockauto.com is one of the best places to get them. URDUSA.com is another.
