P0430
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kaijac03, Jan 5, 2019.
  1. Jan 5, 2019 at 3:49 PM
    kaijac03
    kaijac03 [OP] Well-Known Member
    Kai
    Florida
    2017 Tacoma, TRD Off Road
    The dealership just replaced the seal on my transfer case coming from the manual transmission. Drove it home, all was good. Then did an oil change. Drove to the car wash and got a check engine light. Drove to advance to get the code. P0430. Something about the cats not being efficient enough. I also have a TRD catback exhaust, that I installed over 2K miles ago. Does anybody know what could be causing the code? I have 59,770 miles in the truck.
  2. Jan 5, 2019 at 4:19 PM
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    Typical Toyota O2 sensor code. I’ve had the same code in my old 4buggy.
    kaijac03[OP] likes this.
  3. Jan 5, 2019 at 4:20 PM
    kaijac03
    Kai
    Florida
    As in, I need a new sendor?
  4. Jan 5, 2019 at 4:26 PM
    Marbleyard
    Virginia
    2019 4Runner Pro
    That would be my guess. Some people can get away with cleaning it and reinstalling without rethrowing the code. Just need to figure out which one to pull
  5. Jan 5, 2019 at 4:28 PM
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    P0430 is a catalytic converter inefficiency code. Typically means the converter needs replacing. Also could be bad post catalytic converter O2 sensor. Have you tried clearing it and driving to see if it comes back?
    Edit
    P0430 is bank two. I’m not sure of the firing order on the 3.5. So I can’t tell you what side it’s on, my guess would be the passenger side.
  6. Jan 5, 2019 at 4:30 PM
    kaijac03
    Kai
    Florida
    Thanks. I am driving to NC tomorrow and won’t be back for two weeks. Will have the dealership check it out when I get back. Hopefully their fault and easy fix.
  7. Jan 5, 2019 at 4:32 PM
    Markc1024
    Markc1024 Well-Known Member
    You should be covered under the Emissions Warranty. I'd double check your O2 sensor connections just to be sure they are secure.
    bobsuruncle, kaijac03[OP] and TD90S like this.
  8. Jan 5, 2019 at 4:41 PM
    kaijac03
    Kai
    Florida
    Thanks. I checked the connections. Seem to be good.
  9. Jan 5, 2019 at 4:44 PM
    Bishop84
    Bishop84 Well-Known Member
    They may have banged the exhaust, make sure to take care of this promptly as this is a very expensive catalytic converter and should be covered under warranty.
    Chew and kaijac03[OP] like this.
  10. Jan 5, 2019 at 4:47 PM
    kaijac03
    Kai
    Florida
    Thanks. I have to leave early in the morning to NC. I will call them along the way and might see a dealer while I’m up there. It is driving normal without issue.
  11. Jan 6, 2019 at 1:24 PM
    kaijac03
    Kai
    Florida
    Cleared the code this morning and it has not come back on. Keeping my fingers crossed.
    TD90S likes this.
  12. Jan 6, 2019 at 3:54 PM
    iDrew
    iDrew I spend too much on vehicles...
    Andrew
    Edmond, OK
    '16 TRD Off-Road DCSB
    STOCK AF
    Bank two is drivers side
    kaijac03[OP] and TD90S[QUOTED] like this.
  13. Dec 23, 2020 at 6:34 PM
    EL_INGE2017
    EL_INGE2017 Instagram: @el_inge2017
    Juan Jose
    Los Angeles, CA
    2017 Silver Metallic TRD Off-Road
    TRD Pro Grill, BFG KO2 285/75/16, 16x8 SCS Ray 10 Wheels, Demello Off-Road Bolt-on Sliders, Pelfreybily Skid Plate, Kings 2.5 w/resi and adjusters front and back, clazzio Trd pro leather covers, Baja Designs Squadron-R fog lights, Evilheadlights BHLM headlights, Pelfreybilt Standard Rear Bumper and front aluminum bumper, ATH Bed Stiffners, KB Voodoo Hi Rise Bed Bars, TuffStuff4x4 RTT, SPC UCA
    Any update guys? I have the same issue and last month Toyota replaced my cat under 80k warranty and it did not fix the issue.
  14. Dec 23, 2020 at 6:39 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    It’s an O2 sensor. They probably banged it when they were working on it and either snapped the wire or maybe they had to remove it and forgot to reinstall it. Those things are good for 100,000 miles and should always be replaced together on the same bank if one goes bad replace them both.
    EL_INGE2017 likes this.
  15. Dec 23, 2020 at 6:55 PM
    EL_INGE2017
    Juan Jose
    Los Angeles, CA
    mom almost certain it’s the 02 sensor on the downstream of my exhaust but the code came out before they even touched my cat. I took it in with the p0430 and they suggested replacing my cat.
    I hear people saying to put a non fouler but I don’t want to cheat the system but actually fix it.
    My plan is to swap 02 sensor 1 with 02 sensor 2 and see if I get a different code referring to the upstream 02 sensor.
  16. Dec 24, 2020 at 5:14 AM
    Mastertoytec
    Mastertoytec Member
    02 taco
    We have been seeing an issue with the flanges between the cat pipe and front pipe. not being fully welded. Also seen it around the 02 sensor. Leaks just barley enough to throw a code. Most of the time it takes a year or more to throw a code.. P0430 is the drivers side. If you start your truck cold and have someone plug the tail pipe with rags. You can spray soapy water on the welds and see the leak. Should be covered under Warranty tho
    They also could have left the bolts for the front pipe loose or didn't replace the gaskets for it
