P0440,441,446
Discussion in '1st Gen. Tacomas (1995-2004)' started by sleepetwin, Jun 10, 2017.
  1. Jun 10, 2017 at 1:08 PM
    sleepetwin
    sleepetwin [OP] New Member
    2002 tacoma
    2002 Tacoma check engine light came on with this codes 440,441,446 check gas cap, pass check hoses and replaced one and run EVAP smoke machine and found a leak on the filler pipe hoping this fix my problem
  2. Jun 11, 2017 at 2:43 PM
    ROCKIN RICHIE
    ROCKIN RICHIE Well-Known Member
    BEAN TOWN
    02'TACO
    If light comes on again it's probably a rusted out fuel tank. Get a rubber glove and affix smoker to gasoline filler pipe and watch for smoke at frame at top of tank at straps. If you live any where that salt is used... plan on a new tank.
  3. Jun 12, 2017 at 6:04 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    I've had those codes. In my case I had to replace the charcoal canister because the VSV had stopped working. At the time you could not buy just the VSV, only the entire canister. Since then I also had to replace the VSV for evap under the hood. When those VSV stop working, you'll get evap codes. You can test them with a 12 volt power source. I used some alligator clips on my battery. Disconnect the VSV plug and put power to the contacts. The VSV should open or close, whichever the case may be. No click=no good. It could also be the gas tank. I was luck there; no holes. My CEL has been off since I changed the VSV last fall. That's the longest amount of time since I bought the truck. I also had to change the air/fuel and o2 sensors. Happy camper now though.
