P0440 and p0446 code
Discussion in '1st Gen. Tacomas (1995-2004)' started by Inder, May 26, 2024.
  1. May 26, 2024 at 3:56 PM
    Inder
    Inder [OP] Member
    I’ve had the p0440 and p0446 codes for over a couple years and was wondering what is usually the main cause to fix it. I’ve had the fuel cap replaced, but that never fixed it. Has anyone ever had these codes together? If so, what did you do to fix them? Also, do you know if it is necessary to even fix these evap codes? What will happen to the truck if these codes don’t get fixed for another year?
  2. May 27, 2024 at 5:38 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    EVAP solenoid. Sounds like the purge valve, or you have a crack in your charcoal canister
  3. May 27, 2024 at 6:33 PM
    Inder
    Inder [OP] Member
    Thanks I’ll look into those two.
  4. May 27, 2024 at 7:00 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Replace vacuum hoses in your engine bay and at the charcoal canister. When I replaced my rear O2 sensor due to getting a P0420 code that cleared my P0446 code. I’ve never seen anyone else state the same worked for them but it did for me.
  5. May 27, 2024 at 9:20 PM
    Seastorm
    Seastorm Member
    Monterey Bay
    2004 Double Cab Prerunner
    Recaro Trophy Seats. Bed Shelf with Full Length Pull Out Drawer.
    I have lived with these codes for years also.
    Replaced parts include charcoal canister, fuel cap, vsv valve and filler neck. The codes are much less frequent now after all of that, but yeah the codes still pop up every couple months.
