P0446 fixed.
Discussion in '1st Gen. Tacomas (1995-2004)' started by crainholio, Feb 5, 2012.
  1. Feb 5, 2012 at 8:09 AM
    crainholio
    crainholio [OP] Well-Known Member
    Check Engine light came on last week, I had it scanned at AutoZone and P0446 Evap System was the code.
    I removed my gas cap, cleaned the O-ring seal and the filler surface, and had the guy clear the code. The CE light came back on the next morning.
    I crawled under the truck and inspected the hoses at the carbon canister, nothing wrong and no visible cracks in the canister itself.
    The local dealer had a new gas cap in stock, so I grabbed it. Couldn't see anything wrong w/ my old cap, no cracks in the O-ring, but figured it was worth a shot. Sure enough, after installing it and re-clearing the error code it hasn't come back in the 30 miles I've driven.
    Hope this helps somebody! :D
  2. Feb 6, 2012 at 3:58 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    I had something similar but the gas cap worked for only a short time. Had to replace my EVAP VSV. It was awhile ago however and can't remember the exact code....but I do believe it was the 446. The 442 are the most common codes I get into my shop which is almost always been a loose gas cap in my past experience.
  3. Apr 9, 2012 at 3:01 PM
    ronman737
    ronman737 Dangerous
    Ron
    Greenville, SC
    2008 4Runner 4x4 Sport
    Had the exact same problem. I got a new gas cap at walmart last week and just unhooked the battery today. No more cel.
