p0446, p0441, p0442 fixes?
Discussion in '4 Cylinder' started by brelandt, Nov 21, 2010.
  1. Nov 21, 2010 at 7:42 AM
    brelandt
    brelandt [OP] Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    I'm getting these codes after about 1/2 a tank. Each time I get it the engine is warm. I feel no difference while driving. I replaced my fuel cap and the code is still coming up. Was there a simple fix for anyone that has had these codes? I have the step by step guide to repairing it, but come on that thing is way to long to go through for someone that has to work full time and drive their truck each day. :eek:
  2. Dec 12, 2010 at 9:04 AM
    brelandt
    Terry
    Dublin, CA
    Ok, replaced gas cap with a new OEM one and from Toyota and still withing one tank my light comes back on.
    Getting the code while driving on the interstate and engine is warmed up.
    Any help around here?
  3. Dec 12, 2010 at 1:46 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Did you use www.google.com to find out what each code means?
    You'll find lots of information on google if you haven't already searched this forum.
    Good Luck!
  4. Dec 12, 2010 at 1:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Check the wires going to the Vacuum control valve. Make sure they are not broken, and the plug is secure.
  5. Dec 13, 2010 at 7:32 AM
    brelandt
    Terry
    Dublin, CA
    Did I google it? I've read page after page, but there are too many things that it could be and replacing the gas cap with a factory one was the most common fix. so that's what I did and it didn't work.
    Now I'm asking here cause it sounds like a common issue so somebody might be able to help out so that I'm not wasting my time on things that will not fix it.
  6. Dec 13, 2010 at 8:04 AM
    Janster
    Jandy
    Lancaster, PA
    Did you see these pages?
    http://www.obd-codes.com/p0446
    http://www.obd-codes.com/p0441
    http://www.obd-codes.com/p0442
    Unfortunately...this is something you'll have to further your troubleshooting skills to figure it out. Utilize those pages where they say 'causes' and you'll have to check various other items before coming to a conclusion. Sometimes codes aren't that easy to figure out and why you haven't recevied too many responses.
  7. Dec 13, 2010 at 8:17 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  8. Dec 13, 2010 at 10:55 AM
    brelandt
    Terry
    Dublin, CA
    I'm going to crawl under the truck either today or tomorrow. Hard to get anything done when I live in a super condo and the truck is parked in a dark parking garage, but I'll see what I can see. Thx guys!
  9. Dec 13, 2010 at 12:13 PM
    brelandt
    Terry
    Dublin, CA
    OK, crawled under my truck with a flashlight. Placed my hands on every single line from the tank to the filter. No nicks or cracks. Examed the vacuum lines under the hood including the schrader valve and everything was fine. Checked the valves and the connections and they are fine as well.
    took the gas cap off and followed the lines to the tank. Everything looked fine. Looked down the neck of the fill tank and then I got a little puzzled. Isn't there suppose to be a metal one way door there? Seems that all my other cars has it. Wonder if mine fell off or possible never had one?
  10. Dec 13, 2010 at 12:14 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Nope.
  11. Dec 13, 2010 at 12:39 PM
    brelandt
    Terry
    Dublin, CA
    well that sucks! at least it would have meant something...LOL I also noticed that on the charcoal canister. There is 2 valves mounted towards the inside of them. The one that is closer to the axle has a rubber line coming down from it off of the top of it. I put my hands on it and it's very flexible. Thought it might have popped off of the canister or something but it appears to be normal. Like a vent of some type. Need to get to my diagrams again.
  12. Dec 13, 2010 at 12:47 PM
    brelandt
    Terry
    Dublin, CA
  13. Dec 13, 2010 at 11:34 PM
    garetcurry
    garetcurry Active Member
    Garet
    Round Rock, TX
    2rz and 5vz
    Uggh boy, that looks like a nightmare to troubleshoot. I start lurking on Ebay to get some parts.
  14. Dec 13, 2010 at 11:51 PM
    xroller
    xroller Blowin by em sideways
    Ramon
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    that isn't actually that hard... it's asking you to check the evap system.... shouldn't take to long or you can just buy a new canister....
  15. Dec 13, 2010 at 11:54 PM
    brelandt
    Terry
    Dublin, CA
    Was trying to aviod spending $320 on a new canister. Money is tight. Looked all over the internet before I had went to work and couldn't find one on ebay or even used for that matter. Might be a law selling used emission equipment here in california?
    Going to bite the bullet I guess? Unless I find a Upull it yard.
  16. Dec 14, 2010 at 12:04 AM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    check ur vacuum lines. make sure they are all plugged in. if anything check the one coming from the fuel tank checkvalve, if u see moisture in there its probably sucking in fuel = bad checkvalve, setting the MIL. if still no moisture, the gasket for checkvalve maybe leaking n the evap.system is not holding pressure = bad checkvalve. IMO
    canister rarely goes bad before the checkvalve
  17. Dec 14, 2010 at 7:01 AM
    brelandt
    Terry
    Dublin, CA
    Where is the check valve?
    went over all the lines yesterday and they are all connected and in good condition.
  18. Dec 14, 2010 at 7:15 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  19. Dec 14, 2010 at 7:19 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  20. Dec 17, 2010 at 9:15 AM
    brelandt
    Terry
    Dublin, CA
    I want that boroscope they sell at Sears! Then I could just run that sucker up into any line and see what's up with the diaphragm.
    When I worked on jet engines you brought out the boroscope whenever you wanted to look inside. loved to have one now!
    I think I'll just blow into the valve and see if there is any air moving past it and out the vent.
