P0450, P0441
Discussion in 'General Automotive' started by TXRailroads73, Oct 24, 2018.
  1. Oct 24, 2018 at 7:21 AM
    TXRailroads73
    TXRailroads73 [OP] RÖCKIN'ROLLIN',BEER,YOTAS,MAX/GEMMA
    Adam
    The Lone Star State, RGV, TEXAS
    '23 TRD PRO
    None all stock
    '97 T100 4WD 3.4 V6 345000 miles, CEL came on, code is P0450, P0441 what was your fix to this? Appartenly some dealers have said this part is no longer made, EVAP fuel tank pressure sensor any suggestions???
  2. Oct 24, 2018 at 7:45 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Try PM'g @gunny1005 from Camelback Toyota. If the part can be found I am sure he can find it. And if he can you'll get the TW discount.
  3. Oct 28, 2018 at 12:17 PM
    TXRailroads73
    Adam
    '23 TRD PRO
    None all stock
    Appartenly this is causing my CEL, and research I've done says this part no longer made???
    RobP62 likes this.
  4. Oct 29, 2018 at 10:24 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Weird. Someone has to know what replaced it.
  5. Feb 24, 2020 at 9:21 AM
    gunnar#1
    gunnar#1 Well-Known Member
    sam
    Mesa
    2001 Tacoma 4x4
    Silver xtra-cab,old man emu 3 inch lift, 2016 wheels, arb front bumper, receiver hitch, Automatic transmission cooler, tundra front calipers, new frame.
    I getting the same codes, did you ever figure it out?
  6. Feb 27, 2020 at 8:36 PM
    TXRailroads73
    Adam
    '23 TRD PRO
    None all stock
    Fuel vapor pressure sensor, I joined another forum, Toyota Nation, got some help there, couple members say FVPS off a 97 Taco or Toyota Sienna would work
  7. Feb 27, 2020 at 11:45 PM
    gunnar#1
    sam
    Mesa
    2001 Tacoma 4x4
    Thanks, I came to the same conclusion, I have a used one coming from Ebay tomorrow. I hope it works
    TXRailroads73[OP] likes this.
  8. Feb 28, 2020 at 1:14 AM
    TXRailroads73
    Adam
    '23 TRD PRO
    None all stock
    let me know something please
  9. Feb 28, 2020 at 10:50 AM
    gunnar#1
    sam
    Mesa
    2001 Tacoma 4x4
    will do, do you changed yours and the codes didn't come back?
  10. Feb 28, 2020 at 11:58 AM
    TXRailroads73
    Adam
    '23 TRD PRO
    None all stock
    Haven't had time to find a sensor, you have the link where you found yours?
  11. Mar 1, 2020 at 12:20 PM
    gunnar#1
    sam
    Mesa
    2001 Tacoma 4x4
    eBay $85. I just matched up the part number, the number Ron top im not sure what the one below was for, its the same, the bracket is different but so what, im on day 2 no check engine light so fingers crossed I will try and get emissions tested tomorrow and ill update you
  12. Mar 2, 2020 at 2:40 PM
    gunnar#1
    sam
    Mesa
    2001 Tacoma 4x4
    Passed. FYI last year I did the same thing I tried this year was unhook the battery and won't pass because its not reset and guy tested via the sniffer and it passed fine, this is just a tank vapor bs they won't let me do it that way this year. so it worked, The reset process is apparently 1/4-3/4 gas sitting for 8 hours or more twice and then it will reset.
  13. Oct 12, 2020 at 6:46 PM
    Tanden
    Tanden New Member
    2000 Tacoma Pre Runner
    Thanks for this post!! Saved me alot of time and money
