p0453 code evaporative pressure sensor high input
Discussion in 'Technical Chat' started by Love My Taco, Feb 19, 2010.
  1. Feb 19, 2010 at 2:25 PM
    Love My Taco
    Love My Taco [OP] Active Member
    Justin
    Ohio
    05 TRD Sport xtra cab
    K&N CAI, 110 outlet in cab mod, ARE Cap, Yakima Racks, Stainless Bull Bar, tailgate lock
    Anybody ever run into this? The repair manual says to test the voltage at the sensor, or maybe there's something goofy with the canister, but I wonder if it's something stupid like a gas cap or something.
  2. Feb 19, 2010 at 4:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I've never heard of that code being a fuel cap
  3. Feb 19, 2010 at 4:41 PM
    98tacoma27
    Ben
    Not Beech Creek
    Me either Chris
  4. Feb 19, 2010 at 4:47 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    could be a canister
  5. Feb 24, 2010 at 7:43 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    That code would tell me to look at the canister, and see if it's got a hole in it, or something. Either that, or the sensor is unplugged.
  6. Feb 24, 2010 at 7:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would listen to this guy ^^^^
  7. Feb 24, 2010 at 7:51 PM
    kevhogaz
    SR5 PreRunner
    I always get the canister jobs, when they show up. Just my luck, I guess.
    I had a guy come in all pissed off, because his 4Runner wouldn't pass emissions. Same code, P0453. I open the hood, fully expecting to spend hours tracking down a small leak, with our smoke machine. I took one look at the canister, and noticed a 3 inch crack down one of the seams. Seems the guy forgot to mention it had been smacked hard enough in the front that the insurance company wanted to total the truck. He refused, and made 'em fix it. Unbelievably stupid.
    Don't even get me started on the Mitsu. Evo's we had come in when I was at Tempe Mitsubishi!
  8. Feb 25, 2010 at 7:44 AM
    Love My Taco
    Justin
    Ohio
    Thanks for the input, I'll check it out after work,I just hope my truck with 40k doesn't have a hole in the canister. Hopefully it's a sensor.
  9. Feb 25, 2010 at 8:18 AM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    So what is happening on these that a leak can cause a circuit code? That code is only supposed to set if the pressure sensor reads over 4.9 volts for half a second.
  10. Feb 25, 2010 at 4:42 PM
    kevhogaz
    SR5 PreRunner
    Most likely, either the canister is broken, or the sensor is unplugged. The 0.5 seconds would be an "at least", or minimum amount of time the sensor would read the 4.9 volts.
    From my data, it shows that once you verify that the voltage at the pins is 4.5 - 5.5 volts, you replace the canister. If the voltage is outside of these parameters, you need to start looking for an open circuit, or broken wire. Since wiring problems are almost non-existant on Toyota's, I'd go with a broken canister, or bad sensor.
