P0455 & P0441: Cleared Engine Light, but not Codes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trazerr, Feb 1, 2023.
  1. Feb 1, 2023 at 2:21 PM
    TacoJohn12
    TacoJohn12 Well-Known Member
    Jonathan
    Escondido, CA
    '16 Tacoma - JD Fabrication Long Travel Build
    4" LT, LCA Pivot Kit, SUA, Howe Steering Pump, Switch Pros, Baja Designs lights everywhere, Fabricated Inner Fenders, Custom bumpers, bedcage Fox shocks: 2.5x8 COs, 2.5x8 bypasses, 3.0x16 bypasses, 2.0x2 bumps on all corners... & more
    I recently had the same codes on my 3rd gen. The culprit was the fuel filler hoses. Long story short, my truck has after market wide-body fenders and the filler hoses needed to be extended. Shop that did the initial install botched the filler hose extension & I had another shop fix it. So far no more codes.
    trazerr[OP] likes this.
  2. Feb 1, 2023 at 2:40 PM
    Sysco
    Sysco Well-Known Member
    Jim
    Fort Worth
    2013 Tacoma Base
    I had the same code because of a bad gas cap on my 2013. After replacing the cap, it took several days and a few hundred miles for the OBD scanner to show "ready" on the EVAP test.
  3. Feb 1, 2023 at 2:49 PM
    trazerr
    trazerr [OP] Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    Yeah, something like this is still a possibility for me since that fender was replaced. They could have nicked the filler hose or left an evap line loose. Really hoping it was just the gas cap. It has been in the upper teen's to low 20's last few nights so maybe that helped loosen the gas cap even more.
  4. Feb 17, 2023 at 9:58 AM
    trazerr
    Oregon
    Just to close this out. It must have been the loose gas cap. The check engine light never came back and the codes are no longer on the scanner.
    MGMoverland likes this.
